New Subpanel Almost Works - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2008, 09:38 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
IMO that Allexperts.com site is FULL of mistakes and erroneous advice.
You certainly CAN come right from the main panel for this stuff.
Be aware, there are MANY important codes and rules with regard to pools. One of the main things is for motors and equipment, NO UF cable. You MUST have individual conductors in conduit using an insulated ground. NO, the ground in UF cable is NOT "insulated".
PLEASE, if you intent to do this all yourself, PLEASE have a pro come in and check it out when you are done.
Old 09-03-2008, 11:26 PM   #17
Cow
You know, the best way might to consult an electrician from the beginning rather than the end. Prevent the mistakes before they happen. Pay an electrician for an hour or so of his time and let him show you the best code compliant way to do it. I know I wouldn't mind showing a diyer how to do a job. I'd be quite proud actually, that a homeowner is willing to get an electrician there first to make sure the job is done right instead of just "winging it" and then hoping it passes. That's if it's even inspected you know....
Cow is offline   Reply With Quote
Old 09-03-2008, 11:32 PM   #18
I think that cow has left the barn.
Old 09-04-2008, 07:17 AM   #19
747
registered
747's Avatar
Rewards Points: 534
That would have been the ticket. Then he could have just run the wire where it need to go and have the sparky back to make all conections and verify its good to go.
747 is offline   Reply With Quote
Old 09-04-2008, 08:12 AM   #20
Nec
JerryH3,
My email is soccio97@yhoo.com. Being new to DIY I cannot send the private message yet. Thanks.
soccio97 is offline   Reply With Quote
Tags
electrical , subpanel
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 10:43 AM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 03:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
