New Sub Panel Photos - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-19-2009, 07:17 AM   #16
Originally Posted by Scuba_Dave View Post
I do like the look without all the NMB sticking out everywhere
I had 5 junction boxes near my main panel, and I mean BIG junction boxes. Nothing was labeled, a real mess, old cloth wiring. It was upgraded from 100a to 200a before we bought the house
Fear is looking in your 200a panel & realizing that water is dripping IN your panel from the feed wire. I had the service buried & a new panel installed. I added a 100 sub, 60a sub in the pool cabana
I ran the 5 wires on the side when the old panel was there. The electrician was supposed to run them in the top when the new panel went in. I was pretty ticked when I saw he ran them in the side
I use an excel spreadsheet to track circuits & what they feed
Then I print them out & staple them up near the panel
The three grey boxes on the right are timers for the Christmas display - 40a each. I have a 4th timer - not used yet
To the right of the three boxes there are sets of blank face GFCI's that go to each outside circuit
I like the spreadsheet idea. You know you have all that slack you can rerun them through the top.
rgsgww is offline   Reply With Quote
Old 02-19-2009, 08:54 AM   #17
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by rgsgww View Post
MWBC stands for "multi wire branch circuit" Means we can stick in a double pole breaker (exceptions per 2005 code, required everywhere in the 2008) and feed a circuit with two hots and only one neutral. They share the neutral and the neutral takes the current balance between the two. In a perfectly balanced load, the neutral sees 0 amps.
And the best part.... It (2 hots & a neutral) only counts as 2 CCC when your derating...
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-19-2009, 08:57 AM   #18
DIY'er
jamiedolan's Avatar
I might do that, just want to find a large junction box.
I have two 200 amp panels, one with all of the bx and some new circuits, and one with all of the romex. I will try to clean the panels up sometime. Somebody "lost" 4 screws on each cover. I got new screws for the covers.
6x6x4 at Home Depot =$15
8x8x4 at Home Depot =$22
10x10x4 at Home Depot =$29
*well they are close to those prices, thats the best I can remember. the 10x10x4 is really nice. Make sure you have a drill and tap, they don't come with a hole for the ground screw. The irwin drill bit and tap together (if you can find them together in one pack) for a 10-32 are about $3. I've drilled and tapped many holes with mine and it still works great.
Jamie
Old 02-19-2009, 09:03 AM   #19
Yeah, moving the 5 circuits is on my to-do list. But I also dislike the little covers that go in place of the removed knock-out. But I dislike the wires more
Thanks, the spreadsheet is very handy - especially with rewiring
I also color code the circuits
Yellow means Do not add to circuit
Orange are older cloth circuits to be replaced
---most of these are combined lighting/outlet circuits
I also indicate which circuits are 100% traced for devices
Different color for AFCI or GFCI circuits
With all the changes over the past few years it makes it much easier to change & update what's where
Old 02-19-2009, 09:03 AM   #20
DIY'er
jamiedolan's Avatar
Originally Posted by II Weeks View Post
always learning something new. now I have to look up what the MWBC and what its for and why run 'em.
compared to all the rats nests you see out there, thats one really neat job. I saw some union boxes that were perfect kinda like yours
Thank You.
The MWBC's save you from running an extra neutral, i.e. so you have 2 hots and 1 neutral. I don't really care much about the wire. But you have to be aware of conduit fill. You need to derate your amperage when you have more than a certin number of Current carrying conductors in a conduit. 9 and below allow you to use wire at it's normal amperage. i.e. 12=20A 14=15A.
WithOUT MWBC if you have a 3/4" conduit comming off your panel, you will max it out as follows
4 - 20A branch circuits (could be any amp), you count the neutral with a regular circuit, so 4 circuits, puts you at 8. If you add one more, your at 10, and your over the limit.
With MWBC, you run:
4 - 20A 240v (from a double pole breaker, but you can use tham as 120v circuits), 3 wire circuits, of which one the hot get counted, not the neutral. So you can run a total of 8 circuits in one conduit with MWBC's. Doubling the capicity. That can save running dozens of pieces of conduit in a house / building.
Jamie
Old 02-19-2009, 09:05 AM   #21
DIY'er
jamiedolan's Avatar
Use the screw in type knock outs, they are about $1 each, but are easy to install and don't have sharp edges to scrape the wires. They don'y have them at home depot, only find them at Menards.
Jamie
Old 02-19-2009, 09:07 AM   #22
DIY'er
jamiedolan's Avatar
I am planing on doing a spreadsheet type of setup for here and my parents. It is on my list for the next for days for my parents. Not that it will get used much, as I have things so spread out now, that I'd would not be surprised if they never trip a breaker again.
Jamie
Old 02-19-2009, 09:13 AM   #23
Chicago, IL
Michael Thomas's Avatar
Deleted duplicate post
Michael Thomas is offline   Reply With Quote
Old 02-19-2009, 09:22 AM   #24
DIY'er
jamiedolan's Avatar
Originally Posted by Michael Thomas View Post
It's new in 210.4(D) Grouping. The ungrounded and neutral conductors of a multiwire branch circuit shall be grouped together in at least one location by wire ties or similar means at the point of origination. Exception: Grouping is not required where the circuit conductors are contained in a single raceway or cable that makes the grouping obvious."
In my area some AHJs require something more permanent than electrical tape to meet "wire ties or similar means".
Also, for readers who may come by later, the “simultaneous disconnecting means” requirement for multiwire circuits was expanded in 2008: "(B) Disconnecting Means. Each multiwire branch circuit shall have a means to simultaneously disconnect all ungrounded conductors at the point where the branch circuit originates."
Home Inspection: ""A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
What would you consider more perment than electrical tape? A zip tie is sure easier to cut off than unwraping tape. I use super 33, that stuff doesn't fall off. What are they requesting you use?
For this job, we were still under nec 2005, but I wanted to comply with 2008. The inspectors here are not very complete or diligent, so the burden is really on me to get it right.
Jamie
Old 02-19-2009, 01:14 PM   #25
Chicago, IL
A cable tie can be cut off, but it's more durable long-term than some electrical tape - it's really up to the AHJ.
Old 02-19-2009, 01:17 PM   #26
Rewards Points: 1,910
Jamie, Do AFCIs work on MWBCs?
Old 02-19-2009, 02:03 PM   #27
Yup, if they are double pole.
Old 02-19-2009, 02:20 PM   #28
DIY'er
jamiedolan's Avatar
I agree, but I think they are expensive. AFCI got put off another year in Wisconsin.
Jamie
Old 02-19-2009, 04:04 PM   #29
Jamie
And they sure are expensive.
http://ecatalog.squared.com/catalog/.../17407011.html
Old 02-19-2009, 05:48 PM   #30
Thanks for taking the time and doing a little teaching here. Its really appreciated.
I always ASSumed that anytime I saw a two pole breaker it was for 240 volts but these aren't?
II Weeks is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
DIY Breaker Panel Install - Updated Photos jamiedolan Electrical 31 01-08-2009 01:39 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
