New Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 08:40 AM   #1
Rewards Points: 20
New Sub Panel
I have a 150 amp breaker box in my house which is a sub panel off a 200 amp
feed to my pole barn. The panel is currently loaded. I need to run another sub panel to the house to accommodate a 5 ton geothermal unit. I,m thinking along the lines of a 125 amp box. Two questions. Will 125 amp be
sufficient for the geothermal furnace and a 66 gallon elec. hot water? And the 2nd, what underground copper will I need to for a 150ft stretch?
Appreciate all inputs.
Thanks Larry
v6turboman is offline   Reply With Quote
Old 05-04-2013, 08:51 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
No way to tell without the electrical ratings from the specific equipment you plan on using.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-04-2013, 09:14 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You need to post the nameplates of the equipment you plan on running.
Old 05-04-2013, 09:20 AM   #4
Rewards Points: 20
It is a series 7 Water Furnance Model 060
Old 05-04-2013, 09:21 AM   #5
E2 Electrician
That means nothing to me..
Old 05-04-2013, 09:36 AM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
What size auxiliary heat?
wirenut1110 is offline   Reply With Quote
Old 05-04-2013, 09:42 AM   #7
Rewards Points: 510
With a 5 ton system, I would guess 20 KW aka 19.2 KW strips.
Minimum circuit(MCA) for the unit- 54.1 amps
Minimum circuit for auxiliary heat- 110 amps
Old 05-04-2013, 10:49 AM   #8
jbfan's Avatar
Rewards Points: 650
You can not run another sub panel from the barn to the house, because you have one already.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
rjniles (05-04-2013), stickboy1375 (05-04-2013)
Old 05-04-2013, 11:04 AM   #9
Rewards Points: 20
My Aux strip is a 10k which requires a 60 amp breaker.
The date sheet from the manufacturer shows the units total FLA at 45.8 amps.
Old 05-04-2013, 11:07 AM   #10
Rewards Points: 20
And the water heater is 30 amp
Old 05-04-2013, 05:44 PM   #11
Rewards Points: 510
http://www.waterfurnace.com/literatu...s/SC2700AN.pdf
I was referring to this, the FLA is 45.8 amps but the manuf specs says the MCA is 54.1, 60 MCA for the strips plus the water heater.
Since you can't have another sub panel, all this is moot.
Old 05-04-2013, 05:56 PM   #12
E2 Electrician
Without doing a load calculation, its hard to say if you can just add a sub-panel off your existing pole barn panel, or if you need to increase the existing feeder going to the pole barn, but you cannot have a second feeder going to the same structure.
Old 05-04-2013, 07:34 PM   #13
Rewards Points: 20
Thanks for all the input.
I was unaware that you were not able to add a second sub feed.
This puts new light on my situation.
The Following User Says Thank You to v6turboman For This Useful Post:
Old 05-04-2013, 07:35 PM   #14
E2 Electrician
You may be fine with the existing feeder.
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
