New Stove, Old Wires - 2 Wire Vs 3 Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 01:14 AM   #16
DIYer
Originally Posted by DIYGST View Post
Looking at that link of the product: What does this mean?
ILSCO SK-3 3 SPLIT BOLT, CU/AL, 8-3 AWG RUN AND TAP, TIN PLATED CU
Run Cable Size: (8 SOL/STR - 4 STR AWG) AL OR
That means it takes minimum 8 gauge and maximum 4 gauge. The pre-insulated ones the other guys mentioned look nice though if you can find them.
They do recommend you use the goop on the split bolt even though the wires don't touch. Don't ask me why.
Gigs is offline   Reply With Quote
Old 11-16-2008, 01:34 AM   #17
Its ususally because aluminum never likes to cooperate well in the long time. They usually clean the wires and goop it up, then put it in the lug. Ive seen poco guys do it all the time.
rgsgww is offline   Reply With Quote
Old 01-05-2009, 04:38 PM   #18
Rewards Points: 278
Hi again, back to this problem, I am going to order 3 polaris connectors to connect the 2 hot and ground to the cook top (copper) to the house wire (aluminum)
I was wondering what I need to use to cover up the now un-used, ALUMINUM neutral wire in the same junction box. Would the blue wire nut shown in my pictures be used to cover up the neutral wire, any corrosion problem there?
Since my subpanel is really tight is it OK to not hook up the neutral at the panel if it is not being used?
DIYGST is offline   Reply With Quote
Old 01-05-2009, 06:14 PM   #19
That nut should be fine. To be safe, you could get some anti oxidant for the nut and polaris connectors.
Yes, you can disconnect it, be sure to nut it there again.
Old 01-05-2009, 06:33 PM   #20
Rewards Points: 278
Where can I find some anti oxidant? I looked at the big box and can't seem to locate it. I guess I have to go to a real electrical supply place?
Old 01-05-2009, 07:27 PM   #21
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Lowes has it.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-02-2009, 03:45 PM   #22
Rewards Points: 278
Finally I have sourced some Polaris connector. They have a dab of grease substance inside each hole. I got some Antioxidant made by IDEAL at Home Depot to use with the un-used neutral wire and wirenut will cover it.
Should I use this on the polaris also.. I don't think it's a good idea mix it up with that grease there. The grease in there is probably dielectric which prevents oxidation anyway.
Old 03-02-2009, 04:13 PM   #23
If they have some grease already, I wouldn't put any more in.
3 wire stove connection bgoldie Electrical 13 03-01-2011 12:29 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
