New Shop Electrical Service. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 01:45 AM   #1
New shop electrical service.
I am putting in a new shop, which is to have separate 200 Amp service. My house currently has 2x200 Amp panels, fed from the transformer (pad) about 200 feet away.To bypass the charge for an additional meter, the PUD (Clark PUD in Vancouver, WA) has said they will install a CT meter at the transformer, and remove the one on the house.
Doing this, I need only one meter. The shop is about 120 feet from the transformer in a different direction from the house.
PUD and L&I (electrical inspector) says I need only 4/0 triplex to the shop panel, and do not need a disconnect. Knowledgeable people at the electrical store say I need an additional ground wire + triplex from shop to transformer and a disconnect near the transformer! Was planning on not hiring an electrical contractor
Question is if I need only the triplex to the panel at the shop. Plus, do I need a main lug or main breaker panel, or does it really matter?
Thanks,
Todd
Newbomb is offline   Reply With Quote
Old 05-06-2012, 06:18 AM   #2
Code05's Avatar
Rewards Points: 1,104
You do not need a disconnect at transformer, triplex is fine. It is a service connection, not a feeder.
I assume PUD will tie the triplex to their transformer.
You will need a Main breaker panel or a fused disconnect and MLO panel at the shop unless you have less than 6 breakers in your panel.
You will need a grounding system at the shop, 2 rods is common and the water pipe if it exists and is metallic. Since the shop is new put in an UFER and no rods will be needed.
Code05 is offline   Reply With Quote
Old 05-06-2012, 12:05 PM   #3
Yes, PUD will do everything on the transformer end of the triplex.
Sounds like I need a main breaker. Aside, the Siemens P2040L/P3040L are convertible from ML to MB. What does it take to do that?
Thanks again,
Todd
Old 05-06-2012, 01:47 PM   #4
Code05's Avatar
Thanks again,
Todd
Buying the breaker separate from the panel is going to be way more expensive, but to answer your question: you simply buy a 200 amp breaker that is correct for your panel and install it across the buss bars. It will take up 4 full spaces, 2 on each side.
Old 05-06-2012, 04:41 PM   #5
Actually, I decided the 3040 panel was way too big for a 30x40 shop, and found a g2040b1200cu with main breaker for $89. I guess all panels these days are invertible (bottom feed) so I am set.
Thanks again,
Todd
Old 05-06-2012, 04:44 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Not true. You could only invert it if the MB turned on/off sideways. The MB can not be orientated so that when you push it down, it turns on the panel...only up or sideways.
(that is why we cannot (in the US) mount panels sideways like the do in Canada)
Old 05-06-2012, 05:16 PM   #7
Yes. I verified that. Seems to me that all Siemens panels I looked at were configured this way. Did not see a single vertical breaker.
Old 05-06-2012, 06:34 PM   #8
Code05's Avatar
Lemme guess- you found it at Home Depot? Not commenting-just curious. I did a match google search and that is what I got.
Old 05-06-2012, 08:54 PM   #9
Nope. Grover Electric. Don't shop at Home Depot when I may actually need advice.
Old 05-07-2012, 06:10 AM   #10
Code05's Avatar
Never get advice from any big box store and many supply house clerks are no better. If I may point out your supply house told you that you needed an extra wire and disconnect.
Do I have any more electrical service capacity? (Power for Shed) Magnus357 Electrical 7 10-13-2012 08:52 AM
Need advice for a combination service electrical entrance rlrobinhood Electrical 2 04-21-2011 07:56 AM
electrical service line bmancanfly Electrical 4 07-21-2009 07:07 PM
Help with electrical service hookup near meter! jayp Electrical 12 03-25-2009 11:05 PM
electrical service to barn bsteven Electrical 1 04-18-2005 08:43 PM
