New Service Conductor? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 07:09 PM   #16
Rewards Points: 258
because the curent load center is a known fire hazerd, and some one install three prong outlets without accutal grounds. and there is a 60amp AC unit conneced to the primary disconnect box, which has long black fuses in it, with a small sub panel with two circular fuses in it. And we are not going to ask for the AC duct work that is on the roof to be insulated, or the roof to be recoated.
redman88 is offline   Reply With Quote
Old 10-06-2012, 07:45 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is nothing in the code or anywhere else that I know of that requires that the FPE panel needs replacement. Now, your insurance company may require it be replaced, but how is that the seller's problem? That is between you and your insurance company.
If there are actual code violations, then I agree that those should be addressed by the seller, but having a FPE panel is not a code violation.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (10-07-2012)
panel upgrade , same amperage , service entrance cable
Need help installing new service and making old service a sub panel fightermage Electrical 9 09-26-2012 08:48 PM
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 10:15 PM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
