New Service Conductor? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 01:06 AM   #1
Smile
New service conductor?
Aloha all from Hawaii! Just bought a 40 year old townhouse (six side-by-side units) with all aluminum wiring. Going to change the panel (old and rusted) to the same amperage (100amps) rating, and replace all wiring. Going to follow the same plan as before. Power goes to a meter and service disconnect on the outside of the building, then to my breaker panel inside my home.
Here's my question--do I need to change the the wire coming into the panel in addition to the new panel?
Much mahalo (thank you/with love in Hawaiian) to you construction experts!!!
fire96825 is offline   Reply With Quote
Old 10-06-2012, 01:09 AM   #2
Rewards Points: 258
unless your code is differnt i belive you will have to upgrade to 200 amp, and it would just make sense to upgrade anyway.
redman88 is offline   Reply With Quote
The Following User Says Thank You to redman88 For This Useful Post:
fire96825 (10-06-2012)
Old 10-06-2012, 01:15 AM   #3
Does the NEC require new work to be upgraded to 200amps?
Old 10-06-2012, 01:19 AM   #4
Rewards Points: 258
i am not sure, i just know that the house we are getting ready to buy is going to be upgraded from 100 amp to 200amp as part of the sell, because i dont want less than 200 amps and the rest of the eletrical is out of date but the new main panel will be out side and the rest of the house will be updated at a later time.
Old 10-06-2012, 05:41 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
No, there is nothing that mandates you upgrade to 200A.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
fire96825 (10-06-2012), Speedy Petey (10-06-2012)
Old 10-06-2012, 05:53 AM   #6
Master Electrician
Rewards Points: 3,964
No .
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 10-06-2012, 05:58 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
No, not at all. A load calculation would determine this.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 10-06-2012, 06:07 AM   #8
There is no such code. Kbuz is correct.
Please check your fact before giving advice like this.
In your case it was just a pre-sale strong-arm to get a free 200A upgrade out of the seller.
Old 10-06-2012, 06:09 AM   #9
An old Tradesmen
Rewards Points: 8,170
Please don't make multiple threads about the same subject. threads merged.
The Following User Says Thank You to beenthere For This Useful Post:
Old 10-06-2012, 06:15 AM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Did you buy 1 unit, or the whole thing?
In many places, an owner can not do electrical work on a multi family dwelling.
Old 10-06-2012, 07:02 AM   #11
Rewards Points: 1,548
Am upgrade from 100 amps to 200 amps may require replacement of the service entrance cable from the utility pole and/or the cable from the meter box to the panel. It depends on the thickness of those wires.
If the cables need replacing but are not, then you don't really have an upgrade.
In some cities the owner (without a license) may not do his own electrical work in a multiple dwelling unit even if he owns the whole thing.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 10-06-2012, 12:28 PM   #12
Thank you all!!! Greatly appreciated!!!
Old 10-06-2012, 01:32 PM   #13
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why 200 amps?
Old 10-06-2012, 05:59 PM   #14
Rewards Points: 258
Why would I want 100 amps. Its a 2600 sf home. Also found just this afternoon at the home inspection I have one of these electrical panels in the house. http://inspectapedia.com/fpe/fpe.htm
Old 10-06-2012, 06:48 PM   #15
Because that's what the house came with. WHY in the world should the seller treat you to a 200A UPGRADE?
Tags
panel upgrade , same amperage , service entrance cable
Need help installing new service and making old service a sub panel fightermage Electrical 9 09-26-2012 08:48 PM
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 10:15 PM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
