-   -   New service conductor? (http://www.diychatroom.com/f18/new-service-conductor-159115/)
fire96825 10-06-2012 01:06 AM
Aloha all from Hawaii! Just bought a 40 year old townhouse (six side-by-side units) with all aluminum wiring. Going to change the panel (old and rusted) to the same amperage (100amps) rating, and replace all wiring. Going to follow the same plan as before. Power goes to a meter and service disconnect on the outside of the building, then to my breaker panel inside my home.
Here's my question--do I need to change the the wire coming into the panel in addition to the new panel?
Much mahalo (thank you/with love in Hawaiian) to you construction experts!!! :):thumbup:
redman88 10-06-2012 01:09 AM
unless your code is differnt i belive you will have to upgrade to 200 amp, and it would just make sense to upgrade anyway.
fire96825 10-06-2012 01:15 AM
Does the NEC require new work to be upgraded to 200amps?
redman88 10-06-2012 01:19 AM
i am not sure, i just know that the house we are getting ready to buy is going to be upgraded from 100 amp to 200amp as part of the sell, because i dont want less than 200 amps and the rest of the eletrical is out of date but the new main panel will be out side and the rest of the house will be updated at a later time.
k_buz 10-06-2012 05:41 AM
No, there is nothing that mandates you upgrade to 200A.
brric 10-06-2012 05:53 AM
No .
Speedy Petey 10-06-2012 05:58 AM
No, not at all. A load calculation would determine this.
Speedy Petey 10-06-2012 06:07 AM
There is no such code. Kbuz is correct.
Please check your fact before giving advice like this.
In your case it was just a pre-sale strong-arm to get a free 200A upgrade out of the seller.
beenthere 10-06-2012 06:09 AM
Please don't make multiple threads about the same subject. threads merged.
jbfan 10-06-2012 06:15 AM
Did you buy 1 unit, or the whole thing?
In many places, an owner can not do electrical work on a multi family dwelling.
AllanJ 10-06-2012 07:02 AM
Am upgrade from 100 amps to 200 amps may require replacement of the service entrance cable from the utility pole and/or the cable from the meter box to the panel. It depends on the thickness of those wires.
If the cables need replacing but are not, then you don't really have an upgrade.
In some cities the owner (without a license) may not do his own electrical work in a multiple dwelling unit even if he owns the whole thing.
fire96825 10-06-2012 12:28 PM
Thank you all!!! Greatly appreciated!!!:shuriken::shuriken:
stickboy1375 10-06-2012 01:32 PM
12 Attachment(s)
Why 200 amps?
redman88 10-06-2012 05:59 PM
Why would I want 100 amps. Its a 2600 sf home. Also found just this afternoon at the home inspection I have one of these electrical panels in the house. http://inspectapedia.com/fpe/fpe.htm
Speedy Petey 10-06-2012 06:48 PM
Because that's what the house came with. WHY in the world should the seller treat you to a 200A UPGRADE?
