-   -   New Service for Barn??? (http://www.diychatroom.com/f18/new-service-barn-107686/)
JDTRanch 06-14-2011 04:21 PM
Hello All:
I want to put new service at my barn which is more than 350ft away from my main house power. So instead of killing myself trenching and burying etc.. I want to just install a new service setup at my barn with its own meter.
Now the electrical company is going to put a transformer up and will run the line to my weatherhead. No Problem there.
I have had 2 electricians come out to bid the work and both of them have told me two different things, so I will tell you what I told them and see what answer I get from the pros here.
The barn will basically be powering the following items
1 240v Compressor
1 240v Lincoln Stick Welder
2 Security Lights
8 4ft Flourescent Lights
6-10 110v Power Outlets
Also would like the ability to add on later if need be.
Now I know it requires 200 amp service here in my area. No problem there,
But one electrician said I need a 3 phase socket the other said a single phase will be just fine. I know nothing about electricity so I ask you for help! I ask because I am going to buy all of the stuff for the electrician but I do not want to spend uneccessary money.
So if you can be as detailed as possible that would be great.
I already have a 200amp disconnect box (was told I didnt need this because the socket will be mounted on my barn and can run straight to the inside breaker panel through the wall)
I also have a meter socket with pole and weatherhead, but the label is faded out and there are no markings on it to tell me if it is a 125A or 200A. (Is there a way to tell?)
Will I need a 200A breaker panel inside or will a 125A be sufficient?
I am sure there is something else I am forgetting. I hope somebody can help me. Thanks in advance
JDTRanch 06-15-2011 03:45 PM
I guess nobody can help me with my questions?
jbfan 06-15-2011 04:14 PM
3 phase is not required, and unless yoou live in an industral area, may not be avaible.
The model # on the meter socket will tell you if it is 200 amps.
Does your area require 200 amp min. for a residence?
kbsparky 06-15-2011 06:55 PM
Is that compressor a 3-phase unit? How many HP is it?
That will have to be answered first before determining whether you need single or 3 phase service.
frenchelectrican 06-16-2011 03:01 AM
And it will depending on the POCO requriement and very few case you may get lucky if you have three phase primary right front of ya. { most case gernally not and it can get pretty expensive to bring out unless you have very large load demand then it can be justifed }
1 240v Compressor
2 Security Lights
For the compressour as KBsparky mention the size and voltage requirement
For the stick welder most use 50 amp circuit { single phase is most common unless wire feed welder then it will be mixed bag }
Security luminaire most case useally have either 100 or 150 W HPS { few case super compact flourscent or old school MV ( they are no longer avabile ) }
4 footer is very common typically either 32 or 40 watts depending on if T12 or T8 BTW I rather use the T8 you get more light per watts over old school T12 is. { and of course we have to add ballast loss so go by ballast label for exact amparage it draw }
For genral purpose 120 volt receptales you may need at least 2 maybe 3 circuits and it have to be GFCI there is no extempts on this at all. ( can be on GFCI receptale or GFCI breaker )
If the air compressour is single phase and it draw 30 amp or less and the rest of the items you listed that is more than enough for single phase supply { 200 amp size } the only time you will have to worry if you have very large compressour or other large motour load that will change the figures.
( Just a head up some POCO may have maxuim amount of motour load for specfic transfomer size so if they give you a small transfomer and you install very large motour something like 10 or 15 HP single phase they will change to larger transfomer to handle the motour starting surge )
Merci,
Marc
bobelectric 06-16-2011 03:30 AM
The power company willing to put up"a" xfmr,sez to me 1 . A 200 amp would be all I would bid.
