New Service 320 Amp Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 05:58 PM   #1
New service 320 amp meter
Hi, I hope this makes sense. My wife and I are in the process of building a new house on our current lot. We currently live in our pole shed on our lot which we are building on. When we built the shed the electric company advised us to put a 320amp meter in so we could eventually run two 200 amp panels but pay only one service charge.
Now we are to the point that we are ready to run power to the new house. The meter is currently on the pole shed and is about 15ft from the transformer. We are fine with everything staying on the shed as is. The meter is already set up with dual lugs. The new panel will be in the basement on an exterior wall. I am wondering what I need to do to run power up to the house. I have talked to 3 different electrical contractors and they all say it has to be done differently.
My main questions are do I need to run a new ground up to the new house or are two hots and a neutral fine?
Also, do I need to have a disconnect? If so where should it be located, the shop or house?
Any and all tips and advice is appreciated. Thanks.
F350tony is offline   Reply With Quote
Old 09-12-2012, 06:14 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Is the house attached or detached to the house?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-12-2012, 06:45 PM   #3
Electrical Contractor
kbsparky's Avatar
You make NO SENSE here!
-KB
Old 09-12-2012, 07:22 PM   #4
The pole shed which we are currently living in is a separate building then the house we are building. Thanks again.
Old 09-12-2012, 07:33 PM   #5
electures's Avatar
Oh crap! Attached to the shed? Duh!
Old 09-12-2012, 07:33 PM   #6
electures's Avatar
At least you understood me.
Old 09-12-2012, 08:45 PM   #7
We live in st croix county wi if that helps.
Old 09-12-2012, 10:09 PM   #8
electures's Avatar
Two hots and a neutral to the 200a main breaker panel in the house. Provide a grounding electrode system at the house.
Old 09-13-2012, 06:24 AM   #9
Julius793's Avatar
I would put a fused disconnect by the meter for the house.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-13-2012, 07:06 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
I agree and then use a 4 wire feed to the house. By "fused disconnect" we mean a breaker.
Coastal South Carolina
Old 09-13-2012, 08:13 AM   #11
Rewards Points: 3,256
I would choose a fused disconnect in this case.
zappa is offline   Reply With Quote
Old 09-13-2012, 09:16 AM   #12
electures's Avatar
I disagree. Why?
Old 09-13-2012, 11:24 AM   #13
Julius793's Avatar
I disagree. Why?
Well luckily it's a free country
Old 09-13-2012, 12:17 PM   #14
A "Handy Husband"
rjniles's Avatar
How many homeowners would have spares or even know how to identify and replace a blown fuse
Old 09-13-2012, 01:51 PM   #15
Well.....I really don't know how to answer that and I should have kept my trap shut. I know I wouldn't bother with having spare fuses around because if one blew it would most likely mean I would need more things than just fuses. Maybe even sunglasses and burn cream.
I see it as a convenience item that would never be operated unless I'm replacing the feeder or panel. Being outdoors it seems to me that fuses would be more reliable in the long run.
I don't think I would install any sort of disconnect unless code required it.
Some questions on a new service zappa Electrical 3 11-27-2011 01:30 PM
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 07:55 PM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
New Service msagers Electrical 1 02-13-2008 02:08 PM
