New Service - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 01:23 AM   #1
new service
I want to put a new meter box with 200amp breaker it will be 25' from my main panel in the house what size wire will I need between the 2 panels I'm in tn if it matters thanks
mike cook is offline   Reply With Quote
Old 01-22-2013, 02:37 PM   #2
panel
no one have any ideas
Old 01-22-2013, 03:06 PM   #3
eastcoastsparky's Avatar
Rewards Points: 150
Are u talkin sub panel or upgraded service
Sent from my iPhone using DIY Forum
eastcoastsparky is offline   Reply With Quote
Old 01-22-2013, 03:20 PM   #4
panel
I will be puuting a new meter box with 200 anmp disconect on corner of house about 25' away is the new 200 amp s panel in the house I will be tieing into
Old 01-22-2013, 03:27 PM   #5
Rewards Points: 150
Ok if its a sub panel use 4/0 AL or 2/0 CU with a #6 CU ground, keep nuetrals anc grounds separate
Old 01-22-2013, 03:27 PM   #6
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You will need four wires two hots one neutral and a ground after the disconnect to inside and your panel inside will be a sub panel with neutral and ground separate. 4/0 - 4/0 - 2/0 - #4 AL wire will be needed. Will have to be in conduit unless you use 4/0 SER cable. Would require 2-1/2" pvc conduit.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-22-2013, 03:29 PM   #7
rrolleston's Avatar
2/0 CU is only good for 200 amps when used as a Service entrance conductor. 3/0 CU would be required.
Old 01-22-2013, 03:38 PM   #8
Rewards Points: 150
I must of had a stupid moment your right, using copper is just dumb. If offers no difference when being used as a feeder. Try bending a piece of 4/0 CU into a lug. Hahahaha!!!!!!!!
Old 01-22-2013, 04:40 PM   #9
rrolleston's Avatar
This is what I use for my electric services when I need a disconnect outside.
Milbank Meter Main with Load Center
Moving service panel away from main service line entry k2000lbs Electrical 3 11-28-2011 08:39 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
rewire and new service entrance wire dghowery Electrical 4 10-13-2010 08:31 AM
"Moving" service entrance WillK Electrical 4 09-29-2010 01:04 PM
How to tell Service amperage?? Buckley Electrical 2 06-06-2009 05:42 PM
