Old 10-12-2009, 01:25 PM   #1
Jack of all - master none
hyunelan2's Avatar
New recessed lighting: Line Voltage vs. low voltage
I am going to be tearing out and redoing a ceiling in my diningroom. Around the edges of the ceiling, I am lowering the ceiling 4.5", 1' from the edge (so a trayed ceiling appearance). I want to install some recessed lighting on the part that will be lowered, 4-8 lights - haven't decided that quantity part yet. Since I can use new construction lighting, there are many options. Or, I can just use remodel lighting after the drywall is hung.
The lights I want are smaller, either 3" or 4". I am finding a lot of low voltage lighting in this size. There is no insulation contact in this area. I do want the lights to be dimmable, and that makes me confused with low voltage lighting.
I have installed recessed lighting before, but only the remodel kind and only line voltage. Should I just stick to what I can find in line voltage, for ease of installation and dimmer use?
hyunelan2 is offline   Reply With Quote
More On This Topic
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. This is our electric meter that would measure voltage and oms and dc voltage. What we want to do now is this is a digital volt meter and we... Read More »
Lighting your computer's clear or windowed computer case with Cold-Cathode Fluorescent lights (CCFL) shows off your computer's interior. CCFL lighting provides brighter light than electro-luminescent wiring, but not as bright as light emitting diode (LED... Read More »
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. Today we are going to learn how to install a ceiling fan in your home. We have a standard hundred and ten volt lighting reciprocal here. But... Read More »
Foyer & Home Lighting Tips
Foyer & Home Lighting Tips by Expert Village
My name is Brent Shelly with Expert Village and we are talking about lighting design today. So what are the different layers in a typical foyer. Well depending obviously on the size of the foyer, you definitely want to have a strong decorative layer... Read More »
My name is Brent Shelly with Expert Village and we are talking about lighting design today. When lighting wall art, the best source to use is a MR16. There are twenty different beam spreads and wattages that you can choose from using the MR16. It is also... Read More »
Recessed Lighting gradywhite Electrical 3 06-29-2009 04:45 PM
Recessed lighting in billiard room? kcrossley2 Electrical 11 01-11-2009 09:00 AM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 03:52 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 05:46 AM
wiring for recessed lighting krw3153 Electrical 1 10-04-2005 02:39 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
