Old 11-03-2009, 10:32 PM   #31
Thumbs up Standardization of Plastic vs. metal boxes.
Scuba Dave (Poster #30) Thank you for posting the link for All the various boxes. It's obvious that low voltage boxes have less stringent requirements in terms of enclosure (to protect against arcing/sparking) than standard voltage. That is why they're marked "Low Voltage". As I said in another post that I believe that is the main reason grounding requirements have been changed in the past few years. Because (it really started that way) PVC and other non-metallic materials are becoming more standardized for use in water supply and drainage. Adding to that is the fact that plastic (electric) boxes have practically replaced metal boxes in both Standard and low voltage. (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-03-2009, 11:07 PM   #32
My License Ain't 4 Sale..
The wiremold extension could be bonded by through-bolting a pan head 10-32 with a washer and nut.
If it were me, I'd probably just use the Carlon box on the previous page.
Tags
basement, electrical, shallow wall
More On This Topic
Air purifiers rid the home of dust, smoke and allergens and help clean the air. Purifiers also destroy odors and help lower the humidity. Follow the steps below to build a cost-effective air purifier in the comfort of your home. Read More »
Hi, I'm Aaron Gregory on behalf of Expert Village, and we're going to talk about what happens when your car battery dies; how to select a new battery, and how to see what the problem is. Now when your car won't start, there's a lot of things to check... Read More »
Learn how to grind metal parts smooth when doing body work and restoring a car in this free DIY car-restoration video from our expert mechanic and body shop owner. Read More »
Hi! This is Jon from expertvillage.com. In this video clip, I will be talking about the electrical requirements for a metal shear. On our foot operated metal sheer, it is wired for 220. We have our on/off switch here and that wire runs into this junction... Read More »
Now most milk snakes are fairly small species, not exceeding three feet in length. So you do not need a large enclosure for them. For a full grown milk snake, I would recommend either a twenty gallon tank with cage clips on top, because these guys can be... Read More »
building a wall against an exterior wall Mike L General Discussion 2 08-20-2009 04:50 PM
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 9 07-21-2009 08:21 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 07:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 05:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
