Prev Previous Post   Next Post Next
Old 10-26-2009, 12:59 PM   #1
Default New Recepacles in a shallow wall
Hi,
I'm wiring a basement room that has only 1 1/2" from a concrete foundation wall to the finished surface. I believe it is 3/4 furring and 3/4" plaster. I would like to place 15 amp receptacles in these walls but there will not be enough space for even the shallowest boxes. Can I cut out the location for the boxes and then add a 1" thick spacer block to the finished wall with the same size cut out as the electrical box requires to allow for the depth? Then wire as usual?
trosenda is offline   Reply With Quote
Tags
basement, electrical, shallow wall
More On This Topic
A turbocharger pumps air into an engine to increase its power output. It is driven by the exhaust so the power increases as the engine's revolutions per minute increases. A custom adapter plate frequently must be installed to route the exhaust to the... Read More »
Hi, I'm Doug, I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now Mark's going to tap the hole so that it'll take a bolt to hold the oil pump pickup in place. It... Read More »
Hi, I'm Doug, I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now we're going to do the deed. He's using a good quality air drill just because they are light and... Read More »
Hi I'm Doug. I work with twenty great guys in Saint Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now we're going to get the piece all prepped to reinstall a thermostat. The first thing he does is... Read More »
When making wire jewelry, one of the most important decision is what type of wire you'll use. Down here we have several different types of wire to choose from. Here we have a very pliable silver coated wire. This is great for coiling and doing any type... Read More »
building a wall against an exterior wall Mike L General Discussion 2 08-20-2009 04:50 PM
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 9 07-21-2009 08:21 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 07:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 05:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
