Old 11-24-2012, 01:15 PM   #1
New porch outlet
I need to add an outlet to our porch. In the attic above there is a 20 amp line that feeds a bathroom outlet down below. It is fed from an upstream outlet in another bathroom that is a GFCI. Can I create a junction in the attic that would split the line so one line continues to the outlet below and another now feeds the new porch outlet? There is not enough room in the bathroom box to do the junction there.
Jbsinnc1 is offline   Reply With Quote
Old 11-24-2012, 01:21 PM   #2
New porch outlet
No. This would be a code violation to tap off the bathroom circuit.
teamo is offline   Reply With Quote
The Following User Says Thank You to teamo For This Useful Post:
Jbsinnc1 (11-24-2012)
Old 11-24-2012, 01:28 PM   #3
New porch outlet
Thank you for the quick reply. Something told me to check. I will try to find another outlet to pull from and use a gfci on the porch.
Old 11-24-2012, 02:45 PM   #4
New porch outlet
Is there not an outlet on the inside wall where the porch is?
Old 11-24-2012, 03:07 PM   #5
New porch outlet
Unfortunately no. Opposite this porch is a closet and then next to that is the bathroom I mentioned above. There are no outlets in the closet. I thought about pulling from the line that feeds the closet light switch but it's just not that easy to get to where that line comes into the switch box without treating up some wall. The switch box itself might work but it's just a bit crowded.
Old 11-24-2012, 04:58 PM   #6
DIY Enthusiast
sublime2's Avatar
New porch outlet
Are you sure power is at the switch box for the closet light and not the light it self? Could have a switch loop where power is at the light.could tap off of that if it is at the light.
sublime2 is online now   Reply With Quote
Old 11-24-2012, 07:08 PM   #7
New porch outlet
I did check. The light fixture for that closet and the outside porch light are both accessible from that attic space so that was where I went first, hoping it had been wired that way. Both of those fixtures ended up with the power into the switch and then to the fixtures, so the easily accessible wiring into each fixture is not providing me any help. I wish that had been the case!
Old 11-24-2012, 07:49 PM   #8
joed's Avatar
New porch outlet
What is your location? Add it to your profile. In Canada the outdoor receptacles must be on a dedicated circuit for outdoor receptacles only.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-24-2012, 08:26 PM   #9
New porch outlet
I am in North Carolina. Good point. I'll add that to my profile.
Tags
gfci, outlet.
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 05:20 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
