New Porch Light. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 12:12 PM   #1
Question
New porch light.
I am adding a new porch light. There is a 3 way switch on the inside of the door where I want to put the light. I bought a 2 gang box and a single pole switch and 12-2 wire. The new security light has 2 lights and the wiring is of 2 black and 2 white and 2 copper wires.
I ran the new wire and connected it to the single pole switch and connected the light. I ran a jumper wire from the 3 way switch to the single pole switch for power. I have power at the new switch and at the connection at new light but the light is not powered.
pwspivey is offline   Reply With Quote
Old 03-20-2011, 01:22 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If the power feed is not into the switch box, you are missing either the constant hot or the neutral, And there is no way to wire it with the existing wiring.
Tell us about the wiring that came into the 3 way switch box before you added anything. If you have a single 3 wire cable you do not have the correct wiring.
Coastal South Carolina
Old 03-20-2011, 01:42 PM   #3
wiring coming into 3 way switch
There is a RED, BLACK, WHITE, COPPER. I ran a jumper wire from the red on the 3 way to the black on the single switch.
Old 03-20-2011, 01:58 PM   #4
Old 03-20-2011, 02:20 PM   #5
A "Handy Husband"
rjniles's Avatar
You do not have the power feed you need to power the new switch and light. What you have is a constant hot (the one on the common terminal of the 3 way) and the 2 travelers from the other 3 way. You do not have a neutral. You need to run a new 2 wire cable to a location that has a hot and neutral, a nearby receptacle perhaps.
The Following User Says Thank You to rjniles For This Useful Post:
pwspivey (03-20-2011)
OUtside light should have 120 VAC and has 5-12 VAC dsandine Electrical 3 01-17-2011 12:18 PM
lighting question - porch lights / serial.? MooF Electrical 13 03-05-2010 09:48 AM
Condensation in overhead light JB Toyz Electrical 0 12-06-2009 03:40 PM
Dawn to Dusk Porch Light problem jaw444 Electrical 7 04-20-2009 04:14 PM
porch light and string lights sawtooth Electrical 5 10-03-2008 08:30 AM
