New Plug For Toaster Oven? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 03:27 PM   #1
Rewards Points: 14
New plug for toaster oven?
Hi,
The plug on our toaster oven started to melt right where the prongs go into the plug.
It turns out the internals of the wall socket had rusted and that was the problem. A friend replaced the wall socket BUT I think the heat damaged the cord because the plug itself (not the cord) still gets really, really hot.
I bought a replacemeng plug but once I opened the package it said it was for "light duty" and not to be used on any appliance that generates heat.
I returned the plug and bought this one:
http://www.drillspot.com/products/12...ght_Blade_Plug
Do you think it is the proper plug. Here are the toaster oven specs:
Type 027/ 120 V/ 60 HZ/ 1500w
I'm lost when it comes to things electrical and will appreciate any help or advice with this.
Thanks.
mike720 is offline   Reply With Quote
Old 11-23-2008, 03:36 PM   #2
Rewards Points: 508
Send a message via AIM to theatretch85
Looks like that plug should be adequate only if the appliance is a 2-wire device. Its a commercial grade plug so it will handle the power your appliance needs. 15amps = 1800 watts.
theatretch85 is offline   Reply With Quote
Old 11-23-2008, 03:37 PM   #3
Originally Posted by mike720 View Post
Hi,
Thanks.
Yep, plug is rated 15 amps...toaster is about 12.5 amps.
Was the toaster 3 prong? if so, find one that is 3 prong. If not, don't bother.
rgsgww is offline   Reply With Quote
Old 11-23-2008, 07:44 PM   #4
specs:120 V/1500w
1500w/120v = 12.5A. A 15A plug should work.
Does the new outlet grip the plug securely? This is a bit puzzling.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Oven Building sinr98 Electrical 3 09-13-2008 11:43 PM
GFI Plug Troubleshooting bryanchr Electrical 4 08-22-2008 05:28 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 01:27 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
