-   -   New plug for toaster oven? (http://www.diychatroom.com/f18/new-plug-toaster-oven-32475/)
mike720 11-23-2008 04:27 PM
Hi,
The plug on our toaster oven started to melt right where the prongs go into the plug.
It turns out the internals of the wall socket had rusted and that was the problem. A friend replaced the wall socket BUT I think the heat damaged the cord because the plug itself (not the cord) still gets really, really hot.
I bought a replacemeng plug but once I opened the package it said it was for "light duty" and not to be used on any appliance that generates heat.
I returned the plug and bought this one:
http://www.drillspot.com/products/12...ght_Blade_Plug
Do you think it is the proper plug. Here are the toaster oven specs:
Type 027/ 120 V/ 60 HZ/ 1500w
I'm lost when it comes to things electrical and will appreciate any help or advice with this.
Thanks.
theatretch85 11-23-2008 04:36 PM
Looks like that plug should be adequate only if the appliance is a 2-wire device. Its a commercial grade plug so it will handle the power your appliance needs. 15amps = 1800 watts.
rgsgww 11-23-2008 04:37 PM
Originally Posted by mike720 (Post 189105)
Hi,
Thanks.
Yep, plug is rated 15 amps...toaster is about 12.5 amps.
Was the toaster 3 prong? if so, find one that is 3 prong. If not, don't bother.
Yoyizit 11-23-2008 08:44 PM
specs:120 V/1500w
1500w/120v = 12.5A. A 15A plug should work.
Does the new outlet grip the plug securely? This is a bit puzzling.
