Old 03-06-2011, 04:12 PM   #1
appleye1's Avatar
New Pilot Light Switch - Neutral From Another Circuit OK?
I have a 2 gang box which currently has a 3-way switch on one circuit and a single-pole switch on another circuit. I'm changing the single-pole switch to a single-pole switch with a pilot light (which is on when the light is on.) But the switch needs a neutral. My question is can you pigtail off the neutral from the other circuit that is already in the box?
I've tried it and it seems to work, but I am leery of it.
appleye1 is offline   Reply With Quote
Old 03-06-2011, 04:36 PM   #2
joed's Avatar
No you can not.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-06-2011, 05:00 PM   #3
appleye1's Avatar
Thanks. I'll fish a new wire then.
I assume it is probably against code, right? And although it seems to work it must have dangers or downsides correct? Can anyone explain what those are?
Old 03-06-2011, 05:04 PM   #4
iminaquagmire's Avatar
Current flows back to the panel on the neutral. Connecting the neutral from another circuit means more current flowing back on the circuit than it was intended to handle.
iminaquagmire is offline   Reply With Quote
Old 03-06-2011, 07:07 PM   #5
appleye1's Avatar
Yeah, that makes sense. Thanks for the info.
Old 03-06-2011, 07:08 PM   #6
Licensed electrician
Another reason is to prevent heating from not having all of the circuit conductors run together.
Old 03-07-2011, 04:39 AM   #7
And... When somebody gets Zinged from a circuit they "Know" is off! The neutral is hot.
bobelectric is offline   Reply With Quote
Old 03-07-2011, 09:23 AM   #8
joed's Avatar
Current overload is the main concern. The breaker is on the hot wire. So if each breaker is running 15 amps and one of the neutrals goes open then the remaining neutral caries the full load of 30 amps.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Wiring a single pole switch with a pilot light gabriel246 Electrical 5 10-31-2009 07:03 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
