New Panel Upgrade - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 05:22 PM   #1
New panel upgrade
Hi Everyone,
I'm thinking about having my electrical panel upgraded and would appreciate some advise.
I live in CO and my house was built in 1968. I think the panel is the original as it has a 50amp main breaker with aluminum supply lines from the meter, and it looks old .
I want to upgrade for a few reasons.
1) It is only 50amp
2) All cables inside the house are copper (upgraded a few years ago when I bought the house) as there was a mix of copper and aluminum, so I want to complete the job with a new panel as well.
3) We have added a few more circuits since moving in, so the 50amp box is at capacity (maximum number of breakers installed and being used).
My first question is that if the main breaker is 50amp, I'm assuming that if I upgrade to 200amp (what most people advise me to do) I'm guessing the service cables from the transformer will need to be replaced? If so, will Xcel Energy cover this cost as it's about 100+ feet away from my panel and I don't want to pay for that.
The panel is currently outside. Can I replace this with a panel inside? Same location, but inside the house (I would prefer it inside).
Do you need to install AFCI's now? If so, do I need to rewire the rooms that need AFCI's? (I'm not exactly sure how AFCI circuit work, or if they are different to regular circuits?)
I really appreciate anyone's suggestions.
mikiek is offline   Reply With Quote
Old 01-05-2013, 05:32 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,864
You will probably need a new service drop from the utility. The utility will do the work, but they may bill you for it or they may not. You'd have to ask them. It is possible that the utility will decline to change the service drop because your home's actual load hasn't increased much, just the capacity. This is there prerogative, but you may have to make them change it later if your lights are dimming from excessive voltage drop. You could put the new panel inside, but the more "different" your new installation is from the existing one, the more it will cost since there's more work involved. Moving the panel inside could cost almost the same or far more, depending on the specifics of the installation. Your new panel will require AFCI's and whatever other changes are needed due to the evolution of the code over the decades. AFCI's do not require any changes to the existing wiring, unless you have cross-connections between different circuits or neutral-ground faults in the existing wiring (which was never code compliant). If you have any multi-wire branch circuits that require AFCI protection, you'll have to use 2-pole AFCI's which are very expensive. You may also need additional grounding or bonding for the new panel, depending on what's already there.
I noticed that you seem not to like the aluminum service conductors. This is not an issue, and you can expect your new service to be aluminum also. Only 12 and 14 gauge aluminum branch circuit conductors are considered a safety issue. Aluminum is still widely used for larger conductors and is much cheaper than copper, so it's still more common for anything over about 4-gauge.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-05-2013, 05:34 PM   #3
Rewards Points: 12,914
Originally Posted by mikiek View Post
Hi Everyone,
1) It is only 50amp
Yes you most likly will need to have the power company change the incoming line.
Going to have to call them and ask them about a price. In my area there is no charge.
You will need a permit to do this work!!
I'd strongly suggest you hire a real electrition to do this job for you!
The size of the panel is determinded by the loads, not just a guess.
Depends on what your local codes call for on AFCI. In my area only bedrooms at this time needs it. It has nothing to do with the wiring or the outlets, just the breaker is differant.
Old 01-05-2013, 05:44 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,036
Not all areas require AFCI's or GFCIs with a panel replacement, your electrician should know. I recommend you add GFCI regardless (AFCI not so much). If you only have a 50 amp service today(are you sure of that because it is an usual number?), even houses built in 1968 typically had 100 amp services. You electricain should do a load calculation to determine the size of the service.
Coastal South Carolina
Old 01-06-2013, 01:40 PM   #5
Hi Everyone,
Thank you so much for taking the time to reply to me.
rjniles - I took a closer look today and it is a 125amp panel. I thought it was 50amp as the main breaker is 50amp - my bad. I do have GFCI's in my kitchen, bathrooms, garage and one outside. Would you suggest them anywhere else?
joecaption - I agree. I will get get a few quotes and go from there. I'll look into the AFCI's. If I decide not to replace the panel in the near future (depends on the cost for replacement) I will add the AFCI's for the bedrooms.
mpoulton - Good information about the service cable. If my panel is 125amp, do you think that it can handle more (i.e. 200amp, so I don't have to change it?) - not sure if there was a standard sized cable used in 1968 when installed? Thanks for letting me know about the aluminum service conductors. I did not know this. I hear most people (not electrician's of course talking about aluminum and freaking out about it, so it made me a little nervous.
Old 01-06-2013, 02:11 PM   #6
A "Handy Husband"
rjniles's Avatar
A 50 amp main in 125 amp planel sounds strange, sure you are not interepting something? Show us a pix of the panel. What is the make and model?
Old 01-06-2013, 02:19 PM   #7
Hi Everyone,
Are you sure your main is 50A on a 125A panel? 1968 is a bit late for a 50A service, and it would be odd to have a 50A main in a 125A panel without a very good reason. Can you post pics of the inside of the panel and the service drop connection? There's no way to guess at what the capacity of your service drop conductors are without seeing them.
Old 01-06-2013, 05:56 PM   #8
Hi Everyone,
I have attached some photos - thanks for helping me so much with this...
151219 - shows the 50amp main breaker (all other breakers are 30amp for dryer, 20 and 15 amp - I have a gas cooker) I tested turning this off and it disconnects power to everything in the house.
150939 - Says 'Main rating = 110 - 240V AC 3 wire 125 amps (this is why I assumed it was 125amp)
151036 - In Typical diagram, it says 70amp max branch breakers. I'm assuming that this means that a 70amp breaker is the largest you can install in this panel?
151102 - Not sure if any of this information helps? It was the only other part that I didn't cover in the other photos, so thought I would include.
151418 - Shows the service cables from the meter. I think, looking from the neutral wire it is THW AWG 2 cable? Not sure how many amps this is as it is 60C? Thoughts? It has 7 twisted aluminum stands (not sure if that helps?)
I would really appreciate any help in figuring out what I have and your suggestions...
New panel upgrade-img_20130106_150939.jpg   New panel upgrade-img_20130106_151036.jpg   New panel upgrade-img_20130106_151102.jpg   New panel upgrade-img_20130106_151219.jpg   New panel upgrade-img_20130106_151418.jpg
Old 01-06-2013, 06:08 PM   #9
Need pics that show the whole panel, not just closeups of some parts. Something's not quite right. Unless this is a split bus panel, that 50A breaker is not your main.
Old 01-06-2013, 06:29 PM   #10
A "Handy Husband"
rjniles's Avatar
You have a GE TX1612 panel. It is a 125 amp split buss panel. The top 6 positions are fed directly from the meter and the 50 amp breaker feeds the rest pf the slots below
The Following User Says Thank You to rjniles For This Useful Post:
mpoulton (01-06-2013)
Old 01-06-2013, 06:45 PM   #11
2 more pics uploaded. Inside and outside the panel. Hope this helps. I think you are both right in saying its a split bus. Is it okay to have things attached above the 50amp breaker? There are a few now, including the dryer.
New panel upgrade-img_20130106_162540.jpg   New panel upgrade-img_20130106_162451.jpg
Old 01-06-2013, 06:48 PM   #12
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
edit...
Old 01-06-2013, 07:04 PM   #13
Hi K_Buz,
Not sure what you mean by edit...?
Do I need to edit something?
Old 01-06-2013, 07:12 PM   #14
A "Handy Husband"
rjniles's Avatar
You already have a number of violations:
The top of the panel is limited to 6 handle throws, you have 7.
Multiple neutrals under one screw.
Old 01-06-2013, 07:14 PM   #15
k_buz's Avatar
No, I edited my post. I was confused.
You do have a split buss panel. The top 4(8) spaces are supposed to be used for your 240V loads, including the main for the lower portion of the panel.
As it stands, I think the panel is in pretty good shape, but you do not have any more room in this panel to add circuits even tho it looks like you do.
distribution panel amperage rating tom31415926 Electrical 10 08-26-2012 05:09 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Upgrade panel, add subpanel, add tandem breakers? oregondiy Electrical 11 12-30-2010 11:45 PM
Breaker panel upgrade Jim Patton Electrical 2 11-04-2010 09:47 AM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 08:35 PM
