New Panel For Old House - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 05:07 PM   #1
New Panel for Old House
How many spaces and circuits are required? And how do you know whether you need 100amp or 200amp service? I was told that if installing a hot tub or pool in the future, I should install a 200amp service, is this true?
mdouglas is offline   Reply With Quote
Old 12-01-2010, 05:31 PM   #2
Rewards Points: 324
if your panel is full,and you are going to need more spaces,go 200 amp.hot tub and pool yes to the 200 amp...
oleguy74 is offline   Reply With Quote
Old 12-01-2010, 06:50 PM   #3
Licensed electrician
Rewards Points: 1,020
The size of the service is determined by a demand load calculation.
The minimum number of circuits is; two 20 amp small appliance for the countertops, one 20 amp for the bathroom receptacles and a 20 amp for the laundry. This is in addition to and dedicated to appliances like electric dryers, water heaters, furnaces, air conditioners, etc. You would also have circuits for general use receptacles and lighting.
New Service + Rewire 300 sq. ft. guest house MattFels Electrical 13 11-20-2010 02:18 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 06:47 PM
