New Panel Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2014, 11:11 PM   #1
Hi all
Attached to the house is a panel and attached to that is a sub panel.
What I want to do is run 3/4 PVC, 220v off the sub panel to another panel to a greenhouse. What are some things I need to be aware of/ should know?
I plan on using 10/3 wire off of a breaker on the sub panel
bobbygravelle is offline   Reply With Quote
Old 05-08-2014, 11:16 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Unless the 10/3 is uf cable, it can not be used outside.
What is the load of the greenhouse?
jbfan is online now   Reply With Quote
Old 05-08-2014, 11:21 PM   #3
THHN, I am running it in PVC conduit, and lets say the load of the greenhouse is 80 amps ( which would mean I would run a 100 amp panel, correct? )
Old 05-08-2014, 11:26 PM   #4
jbfan's Avatar
Rewards Points: 224
Thhn is not allowed in a wet location, must be thwn.
No way you can get 80 amps on #10 wire.
The load at the greenhouse will be limited by thd feed to the first subpanel.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
ddawg16 (05-11-2014), plummen (05-09-2014)
Old 05-08-2014, 11:41 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Originally Posted by bobbygravelle View Post
Hi all
What you need to know is that based on your questions you need to hire an electrician.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-08-2014, 11:44 PM   #6
Ok thanks,
I haven't checked the wire size feeding the sub panel, but it's a pretty big wire coming in. Let's say it's 2 gauge, which is rated at 130 amps at 90 degrees. Would I have to run this all the way to a new sub panel by the greenhouse?
Old 05-09-2014, 07:18 AM   #7
jbfan's Avatar
Rewards Points: 224
With out knowing ALL the details, we can what if until the cows come home!
The Following User Says Thank You to jbfan For This Useful Post:
Old 05-09-2014, 07:32 AM   #8
Philly Master's Avatar
Rewards Points: 516
the least expensive way would be to buy #2 Alum. you need 4 wires for a subpanel like this .... its about 1.50 a foot
http://www.homedepot.com/p/Southwire...2801/202316409
you will need 1 1/4" pipe
and FYI for all practical purposes you cannot buy just THHN wire it is all THHN/THWN or dual rated now ...
and the cost would be much higher being that its copper
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-09-2014, 12:07 PM   #9
Some good answers, thank you
Old 05-09-2014, 12:43 PM   #10
Licensed electrician
Rewards Points: 1,236
The wire cannot be used at its 90 degree ampacity.
Old 05-09-2014, 01:00 PM   #11
Rewards Points: 332
First, you need to figure out what size load you will have in the greenhouse. Then based on that information, you can figure out the ampacity and wire gauge needed.
sgip2000 is offline   Reply With Quote
The Following User Says Thank You to sgip2000 For This Useful Post:
Old 05-09-2014, 07:15 PM   #12
It says that #2 aluminum wire is rated at 90 amps, and I want a 100 amp panel, will I run into problems?
Old 05-09-2014, 07:36 PM   #13
A "Handy Husband"
rjniles's Avatar
100 amps to a greenhouse? A grow house?
Old 05-09-2014, 07:38 PM   #14
yes why
Old 05-09-2014, 09:21 PM   #15
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
How about a picture of what you have for an existing service including inside the panels, then we can atleast have a clue of what can safely be run.
Thats why I never give estimates over the phone without seeing the job first.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Replace junction box w sub panel Warchild Electrical 1 02-25-2014 07:32 PM
Use panel as a junction box? LynnX Electrical 18 01-05-2014 06:56 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
