New Panel Costs - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 03-02-2013, 08:30 PM   #16
Rewards Points: 6,652
Originally Posted by Jim Port View Post
Like a website can price something unseen? This is not a tuneup on a car.
Like this site http://repairpal.com/ At least that site gives a better estimate, than the home advisor site.
Old 03-03-2013, 08:58 AM   #17
Rewards Points: 201
Here's a pic of my panel. Looking through the replies it seems like maybe my problem is not enough circuits? We have problems like microwave light flickering ( and tripping breaker when toaster oven on at same time) and lamp lights dimming when turning on room heater.
Zamboknee is offline   Reply With Quote
Old 03-03-2013, 09:38 AM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
A panel change or even service upgrade will NOT solve those issues. That is inherent to the circuits in the home.
My house has a 200A service and all 20A circuits. I still get lights dipping when the A/C or refer kicks on.
Speedy Petey is online now   Reply With Quote
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
jbfan (03-03-2013), stickboy1375 (03-03-2013)
Old 03-03-2013, 10:53 AM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 820
Like speedy said, a new panel is not going to fix your initial problem. Your situation is about par to having a stumble on your engine and the mechanic says you need a new engine.....
The FIRST thing I would do is map out your circuits. Looking at that door, it looks like there is little to no information on what is what. You need to know what each ckt breaker feeds.
On your microwave problem....you need to plug the toaster oven into a different outlet.....you could have a 400A load center and you will still have the same issue. Your trying to run a microwave that pulls anywhere from 1100 to 1500 watts.....and a toaster oven that most likely pulls about 1500W... on the same 20a (2400w) ckt.....no wonder the lights are flickering......
Even if you upgrade your load center, you would need to run more circuits to your kitchen....the load center replacement is cheap compared to running the new kitchen ckts....maybe his quote included that.
Looking at your panel, it looks like you have 3 240Vac breakers. Confirm they are Oven, water heater and HVAC?
Old 03-03-2013, 11:17 AM   #20
Electrical Enthusiast
Rewards Points: 504
I agree with others. The reason your kitchen breaker trips is because a toaster oven and microwave are both high power devices. You should have two circuits in the kitchen, so moving one of these to the other circuit might help.
Unless you're noticing a significant dip, it is fairly normal for incandescent lamps to dim slightly when you turn on a room heater, as they draw a lot of power.
Kyle_in_rure is offline   Reply With Quote
Old 03-03-2013, 02:21 PM   #21
Flickering lights, and dipping circuits can be caused by loose connections. You can add More tandem breakers in there, since it appears that you have a Square D QO panel.
Old 03-03-2013, 05:59 PM   #22
Electrical Contractor
kbsparky's Avatar
That 3rd double pole breaker is not set into the buss all the way....
That panel looks like a QO120M100 which is NOT rated for tandems.
That price should includes things like adding more circuits to alleviate the overloaded ones -- like additional kitchen circuits, as well as separating the lights from the receptacles, etc.
But it still seems to me at least to be a bit high.
-KB
Old 03-03-2013, 06:33 PM   #23
32 Space 100 amp panel (QO32M100VP) http://www.lowes.com/pd_286866-296-Q...t_avg_rating|1 You can probably get the same panel not as a Value Pack from the local Electrical supply house.
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
