New Panel To Code? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-03-2008, 09:47 PM   #16
Electrician
Originally Posted by nap View Post
it is not a GEC, it is a grounding electrode and it is because the code tells us so.
Sorry I never ment to say GEC but GE, and you would only count it as a GE if it is metal and underground for 10'. so my question is, how did speedy know if he had a metal underground water pipe 10' long...
chris75 is offline   Reply With Quote
Old 02-03-2008, 09:50 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by chris75 View Post
Sorry I never ment to say GEC but GE, and you would only count it as a GE if it is metal and underground for 10'. so my question is, how did speedy know if he had a metal in the ground for 10'...
from one of the OP's post previously:
Bcoleman6Thank you for the quick response.
I did think of the requirements before I started the project. I even bought the copper wire to run from the water pipe and ran it from the pipe to just outside the panel.
I was then looking for the answer to #1. Which I admit was something I didn't think of because in the old panel there was only a neutral/ground bar. I then ran into a post saying you shouldn't ground to two places for fear of a grounding loop.
Now as you can see from the picture I have the oven circuit attached to the neutral bar and was 99% sure I needed to ground to the water pipe. Because of the nature of DIY sites I thought I should double check because I had seen conflicting information. As the saying goes “better safe then dead”.
To answer your question: Copper.
Old 02-03-2008, 09:52 PM   #18
Electrician
So how do you know it leaves the house as copper... I have a plastic well pipe at my house , so its not a GE... but I do need to bond the water, but its not the same...
Old 02-03-2008, 09:54 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
The OP stated the pipe entering the house was copper. One can only assume it is still copper 10' out. Have you EVER seen a main feed line plastic up to the house, but change to copper BEFORE it enters??? I NEVER have. WHY would it?
Besides....it DOES NOT matter. If he hits it within 5', and jumps the meter, and the pipe does not extend 10' out, so what? He still needs the ground rod(s), and he is still better off than not hitting it within 5'.
I truly don't understand why you even question this.
Old 02-03-2008, 09:55 PM   #20
nap
You talking to me?
nap's Avatar
So how do you know it leaves the house as copper... I have a plastic well pipe, so its not a GE... but I do need to bond the water, but its not the same...
read the entire thread. It is in another post within this thread.
and what do you mean you have to bond the water?
Old 02-03-2008, 09:56 PM   #21
Like I said. WHY does it matter?
What is the water pipe as it enters the (your) house?
Old 02-03-2008, 09:56 PM   #22
Electrician
I must be blind, because all the OP states is that he has metal piping... nothing about a meter or entering the house being metal...
Old 02-03-2008, 09:57 PM   #23
Come on Chris. Post #3.
Old 02-03-2008, 09:59 PM   #24
Electrician
Plastic... I have a well... its plastic all the way the the expansion tank, then copper inside the house...
Old 02-03-2008, 10:01 PM   #25
Electrician
Look it only mentions he has metal piping... Not everyone has city water you know... Now granted the wire size does not change, BUT he would probably require two ground rods...
Old 02-03-2008, 10:05 PM   #26
WOW!
I asked a question in post #2. He answered it in post #3. The last sentence:
What is the water pipe entering the house? Plastic or copper?
Old 02-03-2008, 10:05 PM   #27
Thank you. I rest my case.
Old 02-03-2008, 10:11 PM   #28
Electrician
WOW!
Thanks that the part I was mis reading, was your post 2, sorry for the delay of game carry on!
Old 02-04-2008, 02:21 PM   #29
I installed a new main panel and just want to make sure everything looks good before the inspector comes out
That aint gonna happen.
Sorry but that is some really ugly work. It looks like a "before" picture.
Is everthing up to code? I don't know, the pics are to small for me to see.
You should have spent a few bucks and had it done professionally.
220/221 is offline   Reply With Quote
Old 02-04-2008, 05:56 PM   #30
Wow, and here I was feeling all proud of myself.
Bcoleman6 is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 05:47 PM
Pigtail inside panel box. Code allowed? KUIPORNG Electrical 7 08-22-2006 03:45 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
