New Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 12:38 AM   #1
Rewards Points: 16
new panel
I have a detached studio on my property built in the 50's, I have removed the old "screw in" style fuse box and all of the wiring and want to install a new panel. The main power source comes from a huge cable that runs about 100ft back to a 100amp knife switch.
What type of panel do I need? Main Breaker, Main Lug, transfer panel? I don't understand the differences.
mikec205 is offline   Reply With Quote
Old 10-27-2010, 01:02 AM   #2
Electrical Contractor
kbsparky's Avatar
Which building is the knife switch located?
If it's in the main building, then a main breaker panel would be needed in the studio apt.
If it's in the studio apt, then another disconnecting means may not be necessary, therefore a main lugs panel could be used instead.
A transfer panel is used when a generator is connected -- will this be the case in your situation?
-KB
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
