#1 |
New outside fixture; light flickers
I have a questions for anyone who can help. I know basic wiring, have books, I am a "do it yourselfer" for my home because I need to save as much money as I can.
So, I replaced my outside light fixture that sits right outside my front door. The light fixture is for outdoors but its not the classic white, black, neutral, its more like the inside type. Brown, ridged goes to white, smooth brown goes to black and copper to ground. I made sure the connections are tight, wire nutted them, and used electrical tape around them. I hook these up, the light works fine and after a few minutes the bulb starts flickering bad. Its one of those 13 watt floresent energy saver bulbs that push in, instead of screwing in. Anyone experience or can share anything about this? Thanks Joe |
#2 |
Electrical Contractor
After the flickering starts, do you turn it off and then back on? Does it work and start flickering again?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
It was a dark and stormy
Flickering might be normal for the burn-in period.
http://en.wikipedia.org/wiki/Compact_fluorescent_lamp |
#4 |
Xtreme DIY'r
Where are you located?
Outside temps? |
#5 |
I live in NJ, yes, its pretty cold out. When I turn the light off and turn it back on again it starts flickering again, like a strobe light.
If its off for a while, and you turn it on, tis fine for less then a minute and then starts flickering again.. |
#6 |
Did you try a different bulb?
#7 |
Xtreme DIY'r
My outside CFL seemed to flicker when 1st installed
Or in really cold weather I haven't noticed it flickering for a while |
#8 |
Another possibilty is do you have a timer to switch this light fixture? Some digital timers dont like CFL's.
#9 |
No, no timer, the unit itself is not a sensor light or anything like that its just a normal fixture that operates from a switch.
I will try and replace teh bulb later today, I have to go to the store and get one. Its the type that snaps in with two prongs, not the screw in type ![]() The light will work fine for less then a minute, then it starts blinking like a strobe light then I just hit the switch down...
#10 |
I don't get it, I replaced the light bulb, it worked for a bit over a minute then started blinkin like a strobe light again. i am just going to take it down adn return it to lowes and get a normal fixture without these special bs prong eneergy saver lights and a normal black, white, neutral configuration. Hooking three wires up and makeing something work has never been so difficult...
![]() you swithc the liught switch off, flip it on, blinks again.. by the way, whats with the brown wires??? |
#11 |
Xtreme DIY'r
Brown wires could be a $$ saving thing
If they only need to buy 1 color wire..... But they still need the ridged & non-ridged I've only used the CFL pin bulbs inside - just recessed lights |
#12 |
Just for laughs, check that the voltage at the fixture is within 5% or 10% of 120v, and that a 10A load drops the voltage about 3v or less.
#13 |
Are they cold temp. CFL lamps?
#14 |
You have a bad ballast in the light. Return it and try something else!
#15 | |
Xtreme DIY'r
New outside fixture; light flickersQuote:
I know there are versions that do not have the ballast built in He tried 2 different bulbs |
| Display Modes | |
| Replacement Light Fixture - Speed Wire Clip? | nick4597 | Electrical | 4 | 01-03-2009 01:49 PM |
| Hall light worked before installing a new light fixture in bathroom | jcfan7 | Electrical | 40 | 02-23-2008 10:46 AM |
| Trying to replace wall mounted light fixture | jtm2300 | Electrical | 4 | 08-03-2007 10:44 PM |
| Part of a ceiling fan light fixture needs help...please | g5729 | Electrical | 1 | 06-17-2007 07:22 AM |
| Old house, new light fixture, too many wires | Persephonee | Electrical | 3 | 01-15-2007 09:58 AM |
