New Outlets Outside - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2009, 04:38 PM   #1
new outlets outside
Im going to be adding some new plugs outside underneath the eve of my house. The correct way of doing this new run is GFCI plug and the other outlets just be plain plugs correct? no need for these plugs to be heavy duty?
Pledgeman is offline   Reply With Quote
Old 10-27-2009, 04:44 PM   #2
Code05's Avatar
Rewards Points: 1,104
Correct GCFI feeds regular receptacles. You will also need weatherproof covers. If you are on the 08 NEC other codes will apply.
Code05 is offline   Reply With Quote
Old 10-27-2009, 04:51 PM   #3
Code05's Avatar
Which state are you in?
Old 10-27-2009, 05:03 PM   #4
i do think i am 08..state of texas..as of right now i have 1 gfci plug 3 regluar plugs..not heavy duty..and covers with the weatherstipping in them
Old 10-28-2009, 10:47 AM   #5
Code05's Avatar
Okay, if you are 08 I believe you are going to have to go with Tamper Resistant and Weather Proof receptacles. Here is a link:
http://www.econline.com/article.mvc/...?VNETCOOKIE=NO
Old 10-28-2009, 10:53 AM   #6
You also need in-use wet covers, weatherstripping covers no longer accepted (may depend upon location of outlet)
Texas was supposed to adopt NEC 2008 by 9/08, local codes can vary
http://www.childoutletsafety.org/fil...doptionMap.pdf
Old 10-28-2009, 01:21 PM   #7
i would have to use the covers even when under an eve? its going to be placed face facing the ground..and the over hang is about ft and half in width
Old 10-28-2009, 01:48 PM   #8
zpm
yeah, right
You don't need an inuse cover. Just an old style flap cover.
406.8
(A) Damp Locations.
A receptacle installed outdoors in a
location protected from the weather or in other damp locations
shall have an enclosure for the receptacle that is
weatherproof when the receptacle is covered (attachment
plug cap not inserted and receptacle covers closed).
A receptacle shall be considered to be in a location
protected from the weather where located under roofed
open porches, canopies, marquees, and the like, and will
not be subjected to a beating rain or water runoff. All 15-
and 20-ampere, 125- and 250-volt nonlocking receptacles
shall be a listed weather-resistant type.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 10-28-2009, 02:53 PM   #9
In use cover depends upon how far the eve of the house sticks out & where the outlet is located
You can't say it doesn't need one or does need one without knowing the location & other factors
Old 10-28-2009, 03:28 PM   #10
zpm
yeah, right
I inferred by post #7 where he said the eave (Eve was Adam's squeeze) was "a foot and a half" that he was going to mount the box tucked up under the eave near the house. There it "would NOT be subjected to a beating rain or water runoff". Any outdoor receptacle is going to be subject to beating rain in a hurricane, so maybe this allowance should be struck in the next NEC revision "just in case".
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 01:08 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
