New Outlets Instead Of Pigtailing - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 08:17 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Losing a neutral is much worse than losing a hot...just ask the electronics on the circuit.
Old 06-29-2012, 08:19 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Not sure i follow? if the circuit is incomplete nothing happens... good or bad.
Old 06-29-2012, 08:27 PM   #18
Master Electrician
it's all bad if you loose the neutral and suddenly put a whole bunch of sensitive electronics in series with 240 volts.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 06-29-2012, 08:29 PM   #19
E2 Electrician
That only happens with a MWBC... I'm still stuck on branch circuits... carry on.
Old 06-29-2012, 09:03 PM   #20
Master Electrician
a mwbc is a branch circuit my arrogant friend. And no nothing will happen if the fault is on a single branch circuit. That doesn't change the fact that it is indeed code in some areas whether you think it's stupid or not.
Old 06-29-2012, 09:08 PM   #21
E2 Electrician
and it's also only a discussion on code, why people need to take it more than that is beyond me, you either agree or disagree, not a big deal.... so chill awhile... learning is something one has to accept as a process. My words are black and white, yet you imply that I'm arrogant.
Old 06-29-2012, 09:20 PM   #22
So with all that being said.. Would you use a regular wire nut on a copper to copper clad connection?
CopperClad is offline   Reply With Quote
Old 06-29-2012, 09:32 PM   #23
Master Electrician
i'm sure there was a thread on that somewhere here
The Following User Says Thank You to andrew79 For This Useful Post:
CopperClad (06-29-2012)
Old 06-29-2012, 09:57 PM   #24
E2 Electrician
Im sure many to follow also...
Old 06-29-2012, 09:57 PM   #25
E2 Electrician
Absolutely not.
Old 06-30-2012, 02:54 PM   #26
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Interesting to note, as we spar with each other, the orginal poster has never returned. A troll as I first thought
Coastal South Carolina
Old 06-30-2012, 04:45 PM   #27
jrclen's Avatar
Rewards Points: 514
He is likely scratching his head, wondering if anyone actually answered his question.
John
jrclen is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 08:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
