Old 06-29-2012, 12:52 AM   #1
New outlets instead of pigtailing
Are there new outlets you can use instead of pigtailing?
Roro13 is offline   Reply With Quote
Old 06-29-2012, 12:58 AM   #2
Welcome to the forum !! Did your pigtails fall apart? No outlet has to have pigtails? Did you do the pigtailing? Please turn the breaker off! Was it by a cabinet? Is the ceiling fan on high or low? Was the TV on channel 48? help !
CopperClad is offline   Reply With Quote
Old 06-29-2012, 07:43 AM   #3
A "Handy Husband"
rjniles's Avatar
You can use any receptacle and connect to the terminal screws. I like the back wired ones (not back stabbed).
Coastal South Carolina
Old 06-29-2012, 09:43 AM   #4
Licensed Electrician
jrclen's Avatar
You will need to use pigtails on the grounds.
John
jrclen is offline   Reply With Quote
Old 06-29-2012, 10:52 AM   #5
Electrical Contractor
You also need to pigtail the neutrals on a MWBC.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 06-29-2012, 11:49 AM   #6
Tool Geek
PaliBob's Avatar
note to the uninitiated MWBC is Electrician Talk for Multi-Wire Branch Circuit
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
jbfan (06-29-2012)
Old 06-29-2012, 11:57 AM   #7
FWIW in Ontario Canada you are required to pigtail the neutral and cannot use the two screws on the receptacle to pass along a neutral in the middle of a run.
I think it is to ensuring higher connection integrity on the neutral.
curiousB is offline   Reply With Quote
Old 06-29-2012, 05:17 PM   #8
E2 Electrician
stickboy1375's Avatar
That is stupid... so what's the difference between loosing the neutral but not the hot? either way, something isn't going to work.
Old 06-29-2012, 07:30 PM   #9
Master Electrician
the reason for pigtailing the grounds and the neutral is so that if the device goes faulty you don't lose your bond conductor or your neutral. If you pull an open neutral at a receptacle along the way the fault will affect every plug or device downstream.
The neutral pigtail is sort of a grey area in Canada that the inspectors don't really look for. Depends on how you read the code on whether or not it is allowed. It is an absolute must on a MWBC. And as stated above on a 3 phase system it's a requirement for shared neutrals.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
PaliBob (06-30-2012)
Old 06-29-2012, 07:33 PM   #10
E2 Electrician
So whats the difference if you loose a grounded conductor or a hot conductor? either way, everything downstream is going to stop working. Meaning, loosing one vs the other is no more hazardous vs the other. This is not directed at MWBC.
Old 06-29-2012, 07:49 PM   #11
MarginallyQualified
Learn how to pigtail. Do it neatly and well.
Old 06-29-2012, 08:10 PM   #12
Master Electrician
yes your correct if the fault is in the lines, the reasoning is that if the device goes faulty then you don't affect the downstream plugs. Or say someone tears off the joining tab between screws. In a 3 phase system if you lose the neutral your looking at having a whole bunch of devices hooked up in series just as you would with a mwbc. But as i said it's a grey area, some inspectors say yes some say no. Personally i haven't found the reference in the code book to prove it has to be done on single circuit residential circuits.
Old 06-29-2012, 08:18 PM   #13
E2 Electrician
So you are saying both the grounded and ungrounded conductors are pigtailed then, not just the grounded... that I can sort of swallow, but really, who cares if you loose one receptacle or ten? its not a hazard either way. It might be an inconvenience to say the least.
Old 06-29-2012, 09:04 PM   #14
MarginallyQualified
The guy who has to come in and troubleshoot the fault.
But usually the problem will still be limited to the J box where the device with the scorch marks is.
Old 06-29-2012, 09:07 PM   #15
E2 Electrician
Aha!
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 09:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 03:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
