New Outlets Don't Work!! - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 05:32 PM   #1
New outlets don't work!!
Hello,
This weekend I replaced all the 15A Type A outlets in my bedroom with Type B outlets (it's an old house) and none of them work except the one that is controlled by the light switch.
Actually what happened was that when I first cut the power back on, only the one controlled by the switch worked. I went to bed and this morning they were all working out of nowhere. When I started plugging stuff back in, 2 mins after plugging in my space heater (to a surge protector) all the outlets stopped working. Again, only the outlet controlled by the switch works.
I wired all the new outlets the same way the old ones were wired. White to silver, black to gold.
Pleased help me figure this out. I am totally puzzled by it! Thanks!
EDIT: I also used a voltage tester on the hot wires and they seem to be dead (in all the boxes). The tester would beep like every 10 seconds as if something was ocming through them intermittently (sp?).
Last edited by SectumSempra; 01-16-2011 at 05:34 PM. Reason: Forgot to add osmething
SectumSempra is offline   Reply With Quote
Old 01-16-2011, 05:35 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
What are type a and tpe b outlets?
Old 01-16-2011, 05:36 PM   #3
When u test for power...are you going black to ground or black to neutral? Sounds like it might be an open neutral...
heartlessmcfly is offline   Reply With Quote
Old 01-16-2011, 05:39 PM   #4
Type A = 2 prong outlet
Type B = 2 prong + ground prong outlet
Sorry for the confusion
Old 01-16-2011, 05:43 PM   #5
I took all the outlets off and just have the wires hanging out the wall right now. When i tested them I was going back and forth between the black wires and the neutral wires.
There actually isn't a ground wire in mine. The old outlets didn't have one connected...
Old 01-16-2011, 05:43 PM   #6
jbfan's Avatar
Rewards Points: 650
Unless you have aground in the box, you just can not change out the receptacles.
How was the receptacle controlled by the switch wired?
Old 01-16-2011, 05:50 PM   #7
Master Electrician
Rewards Points: 3,966
OMG again. First I'll do something, then I'll ask how to do it.
brric is online now   Reply With Quote
Old 01-16-2011, 05:51 PM   #8
That's what I figured until it donned on me about the one controlled by the switch. It's not grounded either.
And again, they worked this morning. They decided to start working sometime in the middle of the night.
Old 01-16-2011, 05:54 PM   #9
jbfan's Avatar
Rewards Points: 650
Unless the switch is operating all the receptacles, you have a loose connection somewhere.
To be code compliant, you need the receptacle in the run to be a gfci , and install no equipment ground stickers on the rest of the receptacles!
Old 01-16-2011, 06:02 PM   #10
No the switch only operates on 1 receptacle.
I'm not sure I understand your last sentence. "To be code compliant, you need the receptacle in the run to be a gfci , and install no equipment ground stickers on the rest of the receptacles!"
Old 01-16-2011, 06:07 PM   #11
jbfan's Avatar
Rewards Points: 650
You can not install a 3 prong receptacle without a ground wire.
What you have is an unsafe condition that can hurt someone!
Old 01-16-2011, 06:19 PM   #12
The NEC states the following:[*]406.3(D)(3)(a) it is acceptable to replace a 2 prong receptacle(non grounding type receptacle) with another 2 prong receptacle.[*]406.3(D)(3)(b) it is acceptable to replace said 2 prong receptacle with a GFCI receptacle and no ground wire needs to be connected to that GFCI.[*]406.3(D)(3)(c) you can replace the receptacle with a 3 prong grounding type without having to connect a ground wire to that receptacle if the receptacle is fed by a GFCI
So if you don't have a ground available you will need to make the first outlet in the circuit a GFCI outlet. These usually come with stickers that say NO EQUIPMENT GROUND to let people no there is no ground. You should place these stickers on the GFCI outlet and any other outlets in the circuit protected by that GFCI outlet.
clydesdale is offline   Reply With Quote
Old 01-16-2011, 06:33 PM   #13
so the receptable the switch is in should be a GFCI? (since that's the only one that works...)
Old 01-16-2011, 07:10 PM   #14
Are both the top and bottom outlet controlled by the switch?
Old 01-16-2011, 07:13 PM   #15
Yes it is.
Tags
outlets , type b
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 01:45 AM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
Outlets Work - Switches Do Not? Quick Electrical 6 08-13-2008 04:10 PM
