New Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 06:45 AM   #1
GBunny
Rewards Points: 71
New Outlets
Is it safe to put 3 new outlets in the basement and run them off existing wires? Can this be done by an unlicensed contractor and then checked by a licensed electrician? Does the safety authority still have to inspect?
GBunny is offline   Reply With Quote
Old 03-26-2011, 08:04 AM   #2
Licensed electrician
Rewards Points: 1,864
I can't speak for the Canadien code, but certain circuits are dedicated to rooms like kitchens, bathrooms and laundry areas in the US and cannot serve other areas. Circuits for fixed in place appliances cannot be used either.
You would also need capacity left in the circuit to serve the new loads.
Old 03-26-2011, 09:23 AM   #3
joed's Avatar
Rewards Points: 13,694
You are limited to 12 outlets(lights, receptacles, fans, etc) per circuit. If the circuit has less then 12 then you can do it.
Can NOT be done by an unlicensed contractor but can be done by homeowner.
Should be inspected but most homeowners would not inspect a small job like this.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
do I need GFI for all kitchen counter outlets DanDaMan Electrical 2 03-06-2011 06:33 AM
bathrooms and outdoor outlets not working maybecalifornia Electrical 1 03-04-2011 06:24 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
