New Outlet Open Ground!!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 03:15 PM   #1
I just installed a new duplex outlet in my garage, the cable was already run from previous owner. I installed a Leviton 8200IG
http://www.fruitridgetools.com/Store...4985822&c=7735
What I get with my tester is OPEN GROUND. The ground is attached to the green screw. I wonder why I get open ground as a result. There's another circuit in the garage and it shows CORRECT on my tester.
Audiotekm is offline   Reply With Quote
Old 06-12-2011, 03:31 PM   #2
DIY staff
Rewards Points: 7,174
Did you open that box to see if that line started there? the ground wire is not 'grounded' wherever it started.
Old 06-12-2011, 03:48 PM   #3
Which "box" are you talking about? The AC comes out of a junction box in the garage, maybe I should take a look at it.
Old 06-12-2011, 03:59 PM   #4
OK so I checked where the line from the new outlet goes and it goes to that junction box. In that junction box it's all 2 wire, the ground from the new outlet is tie to the junction box chassis. For my new outlet do I need to have a little jumper from the ground screw to the box itself (chassis)?
Old 06-12-2011, 04:09 PM   #5
DIY staff
If the box is grounded and the wire is attached to the box you should be good---test the box and see if it is grounded.
I am not very good at describing wiring----sorry if it's not easy to understand.--Mike--
Old 06-12-2011, 04:13 PM   #6
The duplex box is not grounded, just the outlet itself. Do I need to loop from the outlet to the box?
Old 06-12-2011, 05:00 PM   #7
DIY staff
The box does not need to be grounded----when the outlet is installed the screw will ground the box.
I try to avoid answering electrical questions---while I have a good working knowledge I live in an area where Romex is not allowed and all wiring is done with conduit (meaning all boxes and conduit are grounded.)
I'll do the best I can. There are a bunch of licensed electricians here--- They must all be out enjoying the weather.---Mike---
Old 06-12-2011, 08:08 PM   #8
Electrical Contractor
kbsparky's Avatar
You have installed an ISOLATED GROUND receptacle. Separate grounding wires have to be installed on the box and the receptacle.
-KB
Old 06-12-2011, 08:13 PM   #9
Rewards Points: 1,514
Originally Posted by oh'mike View Post
The box does not need to be grounded----when the outlet is installed the screw will ground the box.---
I used to squash the ground wire between the switch (or receptacle) frame (yoke) and the metal box using the mounting screw but an inspector told me I couldn't do that. I was supposed to provide two ground wire ends (using pigtails if needed), one to attach to the switch frame and the other to attach to the box using the green screws provided. Or use a switch with a special spring clip at the end of the yoke where it screws on and then only one ground wire end is needed, attached to the switch yoke.
Old 06-12-2011, 08:19 PM   #10
Rewards Points: 512
In order for there to be an actual ground, the junction box needs to be grounded back at the panel. This is usually done through armored cable. You said the wires in the jbox were all 2-wire, so you need to trace the jbox to see if it actually attaches to the panel with armored cable, rather than Romex.
Old 06-12-2011, 10:33 PM   #11
So what are my options?
Get a regular grounded outlet?
I think the junction box is grounded to the panel. I realized that the breaker for the garage is the same as the master bedroom and all those outlets are grounded
Old 06-12-2011, 10:54 PM   #12
Rewards Points: 512
Do you have a bare grounding wire in the receptacle box? If so, I'd just get a regular duplex receptacle.
Old 06-13-2011, 07:32 AM   #13
If this outlet is in a garage then it should be a GFCI.
hpp58 is offline   Reply With Quote
Old 06-13-2011, 08:40 AM   #14
Note that some armored cables including ordinary BX are not considered good and sufficient grounding conductors. Most qualifying armored flexible cables have a strip or wire for the grounding conductor running inside.
It is not unusual for loose connections to develop between the armored cable, the cable clamp, and/or the junction box at one or more locations, thus giving you an open ground.
Old 06-13-2011, 10:58 AM   #15
That was my first choice but isn't a GFCI outlet more complicated to install???
open ground on a GCFI outlet klaus135 Electrical 23 02-12-2011 09:57 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
How to mount a outlet on a garden ground? KUIPORNG Landscaping & Lawn Care 3 05-30-2009 06:42 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
