New Outlet Near Gas Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 11:28 AM   #1
Willing To Try
It would be helpful to have an additional outlet in a utility room that has a gas water heater. The easiest location is straight through a wall from an existing outlet, but that is within a foot of an existing gas water heater burner. Is there a distance limit for an outlet near a gas burner? I can go up the wall so the new outlet would be several feet from the burner, but it would still be near the top of the water heater.
Catsfan is offline   Reply With Quote
Old 02-11-2010, 03:47 PM   #2
joed's Avatar
Rewards Points: 11,624
No limits I know of.
Old 02-11-2010, 05:26 PM   #3
Even if codes are silent on the relative position of an outlet to a water heater, you still want to make some practical considerations. For example, you probably want to avoid placement where day-to-day use might cause you to bump the temperature control on the water heater.
If there is a more practical location for an outlet farther away from the water heater, you could still come strait through the wall with your wire and utilize surface-mount solutions to run the wire just about anywhere in the utility room: http://electrical.about.com/od/wirin...ntedwiring.htm
http://www.lowes.com/SearchCatalogDi...51&Ntt=raceway
Just research and look for a solution that allows you to use NM cable, or the cable type you plan to come through the wall with. You just have to realize not all raceways are designed for 120v wire.
HooKooDooKu is offline   Reply With Quote
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Stumped. Water heater woes. bigcaddy Plumbing 35 06-14-2009 06:12 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
