New Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2008, 08:38 PM   #1
new outlet
hi would like to hang my lcd tv on wall but need new outlet .I snake my cable wire in wall to tv from basement .I would like to bring power from the basement but do i have to bring yhe power line from the tv to the braker box or can i just cut in to the power wire thats in the basment that run to a outlet thats in the same wall . cut the wire and put a box like in water pipe tee water come in and two feeds come out please help me
doo-man23@comcast.net is offline   Reply With Quote
Old 09-24-2008, 09:16 PM   #2
You can tie into an existing circuit to power your TV.
ALL splices must be made in an enclosed junction box.
Please be careful and make sure all connections are tight!
220/221 is offline   Reply With Quote
Old 09-25-2008, 07:04 AM   #3
Also, remember junction boxes can't be behind the wall, or "flying".
What you need to do before buying some romex is to check the breaker going to the outlets, what size is it? If its 15, then get some 14/2 romex. If its 20 then get some 12/2.
Also you must use a PROPER box, use one of those special boxes for wall mounted tvs.
DO NOT use the push ins, use the screws.
Heres a simple picture showing how the wire should be on the screw. (See how the wires must be orientated so that when the screw tightens, it doesn't push the wire out, it pulls it in.)
rgsgww is offline   Reply With Quote
Old 09-25-2008, 08:05 AM   #4
joed's Avatar
Rewards Points: 13,738
You also need 6 inches of wire inside the box. That means if you cut into the middle of an existing cable there better be enough slack to pull both ends of the cable 6 inches into the box. You might be better off running your TV power cable to an existing box.
Old 09-25-2008, 08:44 AM   #5
thanks you this site is the best people like to help people
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 08:17 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 10:55 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
