New Outdoor Light Fixture Compatibility With Existing Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 08:39 PM   #1
New outdoor light fixture compatibility with existing wiring
When we bought this house, the two old carriage light fixtures on either side of the garage door had had the sensors busted off. One of them works, the other doesn't, and they look bad. So I want to replace them. I've hardwired a smoke alarm before, and also replaced a broken light socket in an old fan successfully, so I think I can handle this.
I looked in the garage first. There is a standard light switch for those lights, but above the switch is a small electrical box sticking out from the wall. On the box is a printed set of instructions on how to flip the switch on/off in order to change from one timer setting to another.
What kind of replacement fixtures should I buy in order to match whatever function this box does? Does it matter? The current fixtures also had small switches on the fixtures themselves.
Thanks for any advice.
fixitmama is offline   Reply With Quote
Old 04-17-2011, 08:56 PM   #2
Solutions (handyman)
Rewards Points: 364
lights
It sounds as though the extra boxes were just a device to cut the power to the lights while making adjustments. I wouldn't be too concerned. The main issue is to make sure you have power to the light fixtures and you're good to go. If the "extra boxes" have a switch, try it (them) to see if they cut power. If not, turn the appropriate breaker off before installing new light fixtures.
The wires should be 14/2 or 12/2 (nothing special) and if they were already in place, chances are everything is fine.
Mark Harvey is offline   Reply With Quote
Light Fixture wiring help jdpitt05 Electrical 7 07-12-2010 01:09 PM
Wiring a new track pendant light fixture achettiar Electrical 1 03-29-2010 01:26 PM
light fixture wiring jasjks Electrical 4 11-29-2006 02:51 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 07:47 PM
New fixture wiring question Unregistered Electrical 1 02-22-2004 07:34 PM
