New/old Construction Low Voltage Brackets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 06:16 PM   #1
New/old construction low voltage brackets
Just a complaint about the term...
I wish they'd use terms for low voltage brackets that describe how they're built and not assume everyone would use "new construction" brackets for new construction. If you're making a receptacle sized hole in the wall, what's the big deal about making it 3/4" wider so you could attach the bracket to a stud to make it stronger? You could use a chisel to cut the drywall that's over the stud.
My case is a little more complex because I think I have wire mesh and bracing, and the bracing is narrower and thicker than a steel stud, but the plaster may be thick enough so I could screw a new construction bracket into the mesh after chipping away some plaster.
Dorado is offline   Reply With Quote
Old 03-18-2013, 07:23 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What the heck are you talking about?
Old 03-18-2013, 07:27 PM   #3
Sparky
Rewards Points: 510
'Old work' items can in most cases be installed without patching the finished wall, and do not require an adjacent stud
'New work' items require a stud, and patching of existing finishes
Techy is offline   Reply With Quote
Old 03-18-2013, 07:38 PM   #4
Yeah, new work brackets in old walls require patching, but if you're installing low voltage brackets, I think you can handle a small patch. I found a new construction bracket with three tabs instead of two, for "extra secure mounting." If two aren't always strong enough, it makes me wonder why I should try an even weaker old work bracket.
Old 03-18-2013, 07:41 PM   #5
E2 Electrician
I don't think new work items always require patching. They just require a fastener driven into a stud, usually. If the wall is solid concrete it wouldn't even need a stud, and I think the mesh in my wall would work with the right fastener. To confuse things more, I found a new construction bracket with three tabs instead of two, for "extra secure mounting." If two aren't always strong enough, it makes me wonder why I should try an even weaker old work bracket.
I've been in the trade a long time and have never had an issue with either new work devices, or old work... not really sure what you are trying to do.
Old 03-18-2013, 07:49 PM   #6
Sorry...I edited my post since you replied...I just want to install a low voltage ring and discovered my choices and I was wondering why I shouldn't choose the strongest. My local big box store doesn't carry new work low voltage rings and I have to go out of my way to get them. I think they're under appreciated.
Old 03-18-2013, 07:51 PM   #7
E2 Electrician
Heres a little tip for you, just nail a plaster ring to the stud, no box.
Old 03-18-2013, 07:56 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Then patch the freaking thing and quit making a big deal about nothing. There are umpteen million different versions of low volt mounts out there. Just because the big box store you went to only had a couple types, doesn't mean that manufacturers have to change the way they name their products. Sheese.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (03-18-2013)
Old 03-18-2013, 07:56 PM   #9
E2 Electrician
Or learn how to install them... lol...
The Following User Says Thank You to stickboy1375 For This Useful Post:
k_buz (03-18-2013)
Old 03-18-2013, 07:58 PM   #10
My local big box store has those plaster rings, but I don't have space for it.
Old 03-18-2013, 07:59 PM   #11
E2 Electrician
My local big box store has those, but I don't have space for it.
You really are confusing me.... why not just post a picture of what you did.
Old 03-18-2013, 08:22 PM   #12
I'm installing jacks in a new hollow wall, shown in red. Maybe in an old wall later on. The spacing is tight but I can do it as long as I don't use the big plaster rings.
New/old construction low voltage brackets-plates-between-studs.jpg   New/old construction low voltage brackets-bedroom-closet-extension-diagram.jpg
Old 03-18-2013, 08:33 PM   #13
k_buz's Avatar
Use something like this and you will only have one ring to cut in.
Old 03-18-2013, 08:49 PM   #14
I know, but I actually don't want two keystone plates. I want one keystone and one telephone. I just didn't buy the telephone plate yet. I want one label for each of the two coax plugs, so I'll use keystone for that. Then I want a real phone jack next to it. I don't think they make a real keystone telephone jack. I'd have to get an extra wide jack, whatever it's called, and put the phone plug in the center. That could be confusing, especially to a future tenant, and residential telephone repair people may not do keystone.
Old 03-18-2013, 08:54 PM   #15
k_buz's Avatar
I'm not even going to try to explain. You go with your plan.
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 08:44 PM
Voltage Problem H. Bruce Electrical 5 09-24-2010 01:14 PM
Reduced Voltage Supply to Outdoor Light mark2741 Electrical 6 09-05-2010 03:44 PM
DC voltage from a PCB dave11 Electrical 3 07-20-2010 07:13 PM
low voltage wiring for niche lighting 8roty Electrical 4 01-16-2010 08:17 AM
