New Machine At Work - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 09:18 AM   #1
New Machine At Work
Hello fellow electrians,
I want to install a new multivac machine (food packing machine) at work and it requires 220volts and 94amps. The closest panel to the machine is only 208 volts is that ok to use? And what type of cable can I order for this? Can I order soow in 100amps?
davepower is offline   Reply With Quote
Old 02-18-2011, 10:52 AM   #2
Rewards Points: 204
If you are indeed an electrician, why are you posting on this DIY site? From your question it does not sound as if you are an electrician or you are very new to this trade.
Go to www.electriciantalk.com. Here you will get professional answers. This is really not the place for this discussion. Just my opinion.
Old 02-18-2011, 10:56 AM   #3
Licensed electrician
Rewards Points: 1,738
Flexible cable cannot be used as a substitute for building wiring. As an electrician I would think you would know this and the proper materials to use.
Is the machine dual rated for the different voltages?
Old 02-18-2011, 11:31 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
A real electrician would also not quote a machine specs as "220v" either, they would know the proper voltage required. Unless of course it was a European machine not designed for the US.
Old 02-18-2011, 07:55 PM   #5
Rewards Points: 506
Is this a rollstock machine?
For the sparky's - this could be a small business owner who wants to do his own install. Although my advice would be to hire it out. Makes insurance more palatable.
Edit: oops...just saw his greeting to "fellow electricians"
jlmran is offline   Reply With Quote
Old 02-18-2011, 08:35 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You guys have it all wrong. He said nothing about being an electrician. He said (and I am copying and pasting):
Now, I must admit I don't know what an electrian is but obviously it isn't anybody that knows much, if anything, about electricity.
Old 02-18-2011, 09:05 PM   #7
Rewards Points: 506
How do you do that? Bifocals?
Old 02-18-2011, 09:35 PM   #8
Rewards Points: 1,532
If the machine instructions or nameplate does not say that the machine can be run on 208 volts (or that it is dual voltage) then the machine probably cannot be.
And the machine instructions will say what the range of circuit amperages will be (recommended amperage and maximum amperage).
You would flame me for being rude and blunt if I simply told you to go hire an electrian or an electrition.
Old 02-18-2011, 09:48 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I would like to have seen a picture of the machine ....
I think an electrian is someone who aides the hiding of elected officials ... like those democrats in Wisconsin.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-18-2011, 09:59 PM   #10
I=E/R
a7ecorsair's Avatar
Just because you have new contacts, now you want to see a picture
a7ecorsair is offline   Reply With Quote
Old 02-18-2011, 10:16 PM   #11
Scared Electrician
Saturday Cowboy's Avatar
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-18-2011, 11:03 PM   #12
Rewards Points: 506
Something similar to this...guessing from the amperage stated. Multivac company offers a complete line of packaging equipment.
http://www.multivac.com/our-products...moformers.html
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
