New Load Center - Your Thoughts - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 11:49 AM   #16
Licensed electrician
Rewards Points: 1,506
I saw what looked like a white conductor in the mix and assumed they were individual conductors.
If they are NM cables the method is still incorrect as the cables are not fastened to the enclosure properly.
Old 02-24-2012, 12:17 PM   #17
Electrician
SD515's Avatar
Rewards Points: 504
I agree.
About the white wire...thinking it might be 8/3 or 6/3 with another cable entering a 1" or 1-1/4" romex/SE clamp.
Kyle
Old 02-24-2012, 12:21 PM   #18
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Why so many cables in one opening. It should be one knockout per cable.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-24-2012, 01:11 PM   #19
Rewards Points: 130
I put two cables in one connector if I need to. Only with 12/2 and 14/2. Never had any issue. I believe the connector packaging has instructions as to how many cables can be used?
Old 02-24-2012, 04:02 PM   #20
Correct John, the packaging will tell you the listed combinations allowed in the connector.
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 11:28 AM
Load center & grounding recommendations lesp Electrical 9 04-15-2011 11:14 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 10:10 PM
