New Load Center - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 03:24 PM   #1
New load center
I need two 200A load centers. Is there a brand and or model that I should get? There seem to be a few choices and would like to know if one is better than another.
HitmanZR is offline   Reply With Quote
Old 07-07-2009, 03:27 PM   #2
Journeyman Wireman
I like Square D the best.
Seen too many GE breakers not trip when they should.
jbberns is offline   Reply With Quote
Old 07-07-2009, 04:02 PM   #3
300zx's Avatar
Post
I like Siemens.All depends on what you like.Cutler Hammer is another choice
300zx is offline   Reply With Quote
Old 07-07-2009, 04:16 PM   #4
I have Square D
I ended up sticking with what was in the house whan I bought it
Both sub-panels are Square D too
Makes it easier to swap breakers
Old 07-07-2009, 07:24 PM   #5
We generally use Siemans because of the copper bus.
SQ D = over rated IMO
220/221 is offline   Reply With Quote
Old 07-07-2009, 08:14 PM   #6
Code05's Avatar
Rewards Points: 1,104
You betcha there are.
Code05 is offline   Reply With Quote
Old 07-07-2009, 09:37 PM   #7
Electrical Contractor
kbsparky's Avatar
Square D type QO panels utilize copper busses as well. HOMELINE panels have aluminum bus.
-KB
Old 07-07-2009, 09:49 PM   #8
Rewards Points: 2,350
Maybe overpriced, but I don't think there is a better brand of plug in circuit breaker and panel on the market than QO. The breakers are solid, and the buss "snap" is oh so tight and reassuring. Others, GE, Siemens, CH, Homeline, all seem to flop around without the panel cover holding them still. I don't like the fact that the panel cover provides mechanical support to actually keep the breaker from moving. I think that support should come from how the breaker is attached to the panel, and I see that in QO.
Old 07-07-2009, 11:53 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
What?.... nobody mentioned the ole pushmatics (bulldog) that bolt on...... BTW save the breakers if you demo out a panel you will be glad you did.
My choice (if I get one) copper busses and of those I like the QO. Second I like cutler hammer ch (tan toggles) not the BR. The older CH with the tan colored can was hard to beat.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-29-2009, 08:55 AM   #10
Cutler Hammer CH Loadcenters also have a copper bus.
nomad4137 is offline   Reply With Quote
Old 08-29-2009, 10:48 AM   #11
Rewards Points: 252
2 - 200 amp panels. Are you sure thats all you need to know?
Old 08-29-2009, 01:00 PM   #12
Idiot Emeritus
Rewards Points: 1,492
Coming form a commercial/industrial background, (also known as 'high abuse' environments lol) I'd recommend Square D QO. I realize that most of the panels I work with use bolt-on breakers, but there are plenty of push-ins as well.
I've seen fewer burn-ups with Sq D, and the breakers (both bolt-on and push on) seem to do a bit better at differentiating between a motor starting surge and a short or ground fault.
GE was mentioned above, I test breakers occasionally (usually for certification of some sort), and I've seen GE breakers fail to trip. Even with several hundred amps across them. It's rare, but it does happen.
I'm also pretty impressed with Siemens though. Since QOs are considerably more expensive, Siemens may well be the most economical.
Rob
micromind is offline   Reply With Quote
Old 08-29-2009, 01:28 PM   #13
" Euro " electrician
frenchelectrican's Avatar
I used one of the three most items .,,
SqD QO series
Seimans
CH CH classic series
Those three is good but there are other good one as well but not GE it is not on my list at all { have past issue with them before }
Pushmatic jezz that is good one but wish they stay around and make new one that is really rugged one I know it seems old school but not get much call back realted to them due they are true bolt on design.
Merci,Marc
Old 08-29-2009, 03:02 PM   #14
Rob
Whoa. What? Really? Were counterfeits ruled out?
See, this just disturbs me, because I have a perfectly functional GE panel in my shop, and have pretty much decided on replacing the hokey over-stuffed Bryant panel in my house with a GE panel. It just makes sense for me to stick to one brand on the property for maintenance reasons.
I haven't done a lot of load center installations, but I'd bet I have done more than most other DIY guys. Aside from one CH that I installed several years ago, I have used GE panels exclusively. Maybe I'm missing something, but they seemed like a good value. Copper bars, no one complaining about them starting fires, and they can be easily found in white, which looks a lot better in a living space than grey.
Just when I think I know what works for me, someone comes along and says something that makes me question my decisions.
KAdams4458 is offline   Reply With Quote
Old 08-29-2009, 05:05 PM   #15
The NEC code book, has up the AFCI breaker requirements, meaning more locations, then ever before.
These AFCI are bigger than their standard circuit breaker, I hate having the breakers extend over
the bus bar. So I would recommend a QO SD MAIN CIRCUIT BREAKER panel, which is Service Rated.
I don't recommend their Homeline Series. Do a side by side comparison, you'll see what mean.
Ranger31 is offline   Reply With Quote
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
Load Center Replacement - with or w/o main breaker? shepiii Electrical 3 01-30-2009 11:04 AM
Termite repair to load center wall - precautions shepiii Electrical 3 01-21-2009 04:14 PM
Load Center dwayne Electrical 4 07-09-2006 01:02 PM
