New Line From The Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 07:48 PM   #1
Rewards Points: 12
New line from the meter
I'm planning on running electricity out to my shed. Since I don't have any open breakers in my box I want to just run a new line off of the meter out to my shed and install a small box there that can power, at most, a small table saw.
My questions are:
Does this sound like the best plan?
What will tying in at the meter entail? Will I need to have the power company shut off the power to the house?
jseymour186 is offline   Reply With Quote
Old 03-11-2013, 07:50 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Unless the meter has lugs for 2 wires, this is not allowed.
Old 03-11-2013, 07:55 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You could always install a junction box below the meter and splice the load side of the meter for the house and the separate structure, this has a good advantage because since this is still considered service entrance conductors you will only need 3 conductors to your remote structure.... proper disconnects and grounding electrode systems are required at each structure...
This will require the power company to turn off your power while you perform the work.
Old 03-11-2013, 08:29 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
There is a near 100% chance this is not doable.
Speedy Petey is online now   Reply With Quote
Old 03-11-2013, 08:52 PM   #5
Rewards Points: 83
go pull a permit and see whar they say <grin> talk to the local inspectir about doing this.
mech_gui is offline   Reply With Quote
Old 03-11-2013, 09:00 PM   #6
Electrician
Rewards Points: 778
Sounds like it would be easier to install a small sub panel at the main panel.
darren is online now   Reply With Quote
Old 03-11-2013, 09:05 PM   #7
E2 Electrician
all depends... I can't see what's involved.
Old 03-12-2013, 01:11 AM   #8
Rewards Points: 160
J - When you say there're no empty slots in your panel, have you used tandem breakers everywhere you can? If not, that's 1000 times less work and less complicated than messing with the meter. You may also be able to replace a two-slot 240 V breaker with a quad, which will free up two spaces. All depends on the make and model of the existing panel.
philS is offline   Reply With Quote
Old 03-12-2013, 01:25 AM   #9
It is done all the time for central air!
Hardway is offline   Reply With Quote
Old 03-12-2013, 07:03 AM   #10
E2 Electrician
What is?
Old 03-12-2013, 08:56 AM   #11
Rewards Points: 1,448
What is?
Use of double wide quad breakers or single wide double breakers (tandem breakers).
Note that you are limited to so many breaker handles in the box. This number should be stated on the box label and this can limit the number of tandem breakers you can use.
But you can commandeer two slots for a (double wide double) breaker for a 120/240 volt feed to a subpanel and move several circuits from the main panel to the subpanel.
Old 03-12-2013, 12:01 PM   #12
Rewards Points: 82
They do make double lugs for meters, but how you would fit all the wires in the meter can would be an issue? Tapping the service conductors may be your best bet. This should be done by a qualified licensed and insured electrician or contractor.
The Following User Says Thank You to J. V. For This Useful Post:
stickboy1375 (03-12-2013)
Old 03-12-2013, 11:00 PM   #13
Rewards Points: 12
Thanks for the comments. It is apparent that there are some options I may not have thought of. In any case it appears that it is going to be a little more complicated than i was thinking. Thanks again.
Old 03-13-2013, 03:45 AM   #14
What is?
New line off of the meter!
Old 03-13-2013, 03:48 AM   #15
What is?
New line off of the meter can!
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
320Amp double lug meter - (2) 200amp panels 1texasguy Electrical 31 07-15-2011 11:47 AM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 03:29 PM
Water supply line blackhemi Plumbing 4 04-09-2011 09:18 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
