New Line For Bathroom(hairdryer Use) - Should It Be A 20a?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2009, 06:47 PM   #1
New line for bathroom(hairdryer use) - Should it be a 20a??
I'm thinking that I can run some new wire to my box(maybe...i'm gonna try) to hook up a plug(GFCI) in my bathroom...no existing plugs in there yet. My wife will be using that plug for the hairdryer mostly. So should I put a 20 in the box? I think I should. I should obviously use 12/2 wire right?
what are your thoughts on this.
Also I may have to run the wire beside a iron pipe(I'm pretty sure its not a drain pipe...I think it is the pipe that is like an air vent that goes all the way up my house to the roof). Anyway, is this not good to do? and also what are some general rules of thumb when running wire? Some do's and don't i guess. Should I use the wire with the metal casing(I think its called conduit) for this job??
Oh yeah and it probably doesn't matter but my box has no 20's in it only 15's, 30's and 40's. The 30's and 40's are double(attached like one breaker switch)
The previous owner had a hot tub and I think it was on the 40???
Thanks,
Steve
Limit54 is offline   Reply With Quote
Old 11-12-2009, 06:53 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
In the US a 20 amp circuit is required. I think I saw where Joed had stated that is not the case in Canada.
The wire can not be run inside the pipe, but it can be run along side the pipe.
Old 11-12-2009, 06:59 PM   #3
No I wouldn't run it inside the pipe just along the pipe because that is the only route of entry I can get the wire down from the top floor to the basement so I can run a new line. i still have to try and do this and see if it is possible. Lets just say for arguments sake that the pipe was running water in it..then is it still ok?
Old 11-12-2009, 08:40 PM   #4
Thumbs up
JB was being funny when he suggested you should run it ALONG the pipe not INSIDE the pipe. Anyway. Regardless of what the Canadian Electrical Code requires in terms of Minimum Capacity 15/20A. It makes sense to run a 20A. line, as long as you're running a new line. Besides. High Capacity Hair Dryers, properly run on High Wattage. so, it's better not to strain the wire and run it close to its capacity. (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-14-2009, 07:12 PM   #5
ok perfect...thats exactly what i was thinking.
Thanks so much.
Hope I can fish the wire to do this.
Old 11-14-2009, 08:21 PM   #6
joed's Avatar
Rewards Points: 13,308
20 amp is not required in bathrooms in Ontario. If you use 20 amp you can NOT put lighting on that circuit. Lighting is required to be on a 15 amp circuit. You must use a 20 amp T slot GFCI receptacle.
Old 11-15-2009, 08:05 AM   #7
Rewards Points: 352
If it is a dual receptacle (can plug in two things) why do you need a T - Slot type (20 amp) receptacle? I thought all GFCI receptacles were rated at 20 amps and the dual aspect of it handled the code issue???
Rege
RegeSullivan is offline   Reply With Quote
Old 11-15-2009, 08:13 AM   #8
Rege
Canada has different codes then we do
Some are close to the same, but there are differences
Old 11-15-2009, 09:02 AM   #9
joed's Avatar
Rege
Because the code in Canada says a 20 amp circuit must have a 20 amp receptacle. You could use a 20 amp receptacle with the one slot sideways and only be able to use 20 amp devices or you could use the 20 amp with the T slot and be able to use 20 amp or 15 amp plugs.
Old 11-15-2009, 09:34 PM   #10
ok so here is what happened. I couldn't fish a new line, so i ran the GFCI on a line that that powered my old lights in the bathroom. I am no longer using that line for the lights. The line is on a 15 amp and i checked my GFCI and it says that it is a 15a...so I guess a 20 was out of the question anyway.
Thanks so much for the help you guys are awesome.
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
