New Light Switches Keep Blowing? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 02:45 PM   #1
Exclamation
New light switches keep blowing?
I recently had electrical issues at home and ended up determining that a wire had broken up in my attic, and a circuit breaker had broken. I installed a new breaker and ran the wires up to the light switch. I've wired it up and when I turn the breaker on, the switches keep blowing. The lights turn on, but when I try to turn the switch off, it pops the breaker and the switch is off. I've tried 3-4 switches now, followed the wiring diagram, and have no idea what to do? PLEASE help me, I'd rather not have to call an electrician.
Thanks!
Electricalprobs is offline   Reply With Quote
Old 08-10-2009, 02:57 PM   #2
Licensed Pro
You obviously have the switches wired incorrectly. You need to detail exactly what you have and what you have done... pictures would be great.
Old 08-10-2009, 03:04 PM   #3
Unfortunately I'm at work right now, but I can look at the details when I get home. The only thing I don't understand is that the new breaker also powers another room, which is working just fine. I've tried wiring the switches both ways, and both seem to keep blowing. Like I said, I'll get back with more details here in a few hours.
Heres what I know:
The new breaker is a 20amp
The light that keeps blowing only has 5 bulbs at 25w each.
The other room only has 2 lamps and a TV, all of which work fine.
Thanks for the quick response!
Old 08-10-2009, 03:41 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,938
Heres what I know:
Call an electrician. With any normal, code-compliant installation, there is no way to trip a breaker by turning a switch off. That this is happening is a clear sign that something is very wrong with the installation (not just a little wrong). That you can't figure it out is a good indication that you're in way over your head on this type of a troubleshooting - the chances that a bunch of people are going to be able to walk you through it over the internet are slim.
My guess is that this is a 3-way installation wired as a "California 3-way", and you moved the breaker to the other hot leg when you replaced it, which would result in a dead short when the switch is turned off. If that's the case, it will require re-wiring the whole circuit to make it code compliant.
mpoulton is offline   Reply With Quote
Old 08-10-2009, 04:13 PM   #5
Fixed it.
I was using 14 gauge wire on a 20amp breaker. Switching it to 12 gauge wire seemed to fix the problem. The lights are turning on, and off with no issues. I will continue to monitor it and call an electrician if I see any issues with it
Thanks!
Old 08-10-2009, 04:21 PM   #6
Fixed it.
Thanks!
That was definitely not the problem. While you certainly shouldn't use #14 on a 20A breaker, the symptoms you described CANNOT be a result of that. The only problem with using undersized wire is that it may overheat and start a fire without tripping the breaker in case of an overload. I would say you connected things differently when you rewired it.
Remember, just because it seems to work does NOT mean it's done right, or safe.
Old 08-10-2009, 04:31 PM   #7
I also used a new switch this time, because i could tell the other switch was blown. It seems to still be working though. However, a friend of mine is an electrician who's going to come check it out for me tomorrow.
Old 08-10-2009, 05:30 PM   #8
These symptoms and "fixes" don't make sense, which means we are assuming some thing, or things, which are not true.
Be careful with what you're doing.
Old 08-10-2009, 05:43 PM   #9
Yeah, something doesn't make sense to me either, which is why i've given up for the night. I turned off the breaker, and put wire nuts on all the exposed wires. I'll just wait for the electrician to come tomorrow.
Thanks for the help though!
Old 08-10-2009, 06:14 PM   #10
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
That's very strange, I would definably get an electrician to check this. Is it 3 way switches? You could use speaker wire or 0 guage, it should not matter, it will still work the same. Of course you need to use the proper wire for the proper amperage, but that is a code and safety issue, not functionality. Changing the wire probably somehow fixed the problem, but I would not call it fixed until you know exactly what was happening.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Separating Fan and Light Switches GeauxCajuns82 Electrical 11 08-26-2008 12:03 AM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 01:57 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
