New Light Switch With New Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 08:17 AM   #1
New light switch with new wiring
I have new wiring installed ( romex simpull AWG 12 ground type nm-b). There are two sets of wires coming into the light switch box. One is hot, neutral and ground. The other is going to a overhead vanity light. I have installed a Pass & Seymour lighted switch (15 amp, 1 pole paddle style). I connected the two neutrals together and put both blacks to the switch. Also connected ground. I have confirmed there is power coming in. The switch does not light and lights do not work. I would like to ask if my wiring is correct.
Towerdog2 is offline   Reply With Quote
Old 09-21-2011, 08:28 AM   #2
looks ok...trouble shoot this by connecting the 2 blacks together with out the switch
Marbledust is offline   Reply With Quote
Old 09-21-2011, 08:45 AM   #3
joed's Avatar
Rewards Points: 13,308
How did you confirm voltage? Did you measure voltage between black and white? Could be an open white. Could be a false reading of power if the black is open.
Old 09-21-2011, 08:54 AM   #4
I have connected both blacks and no power
Old 09-21-2011, 09:43 AM   #5
Have 118 coming in between black and white. With switch on between the other black and white is 101.5 and switch off is 65.4.
Old 09-21-2011, 10:20 AM   #6
I=E/R
a7ecorsair's Avatar
Your reading don't make sense. Do this but be careful. Leave it wired up as in the picture but unscrew the wire nut on the white wire and then take your voltage reading with the switch on and off. You may be able to do this with the wire nut on if you can touch the wires inside the nut with your probe. Are you using a volt meter?
a7ecorsair is offline   Reply With Quote
Old 09-21-2011, 11:21 AM   #7
I am using a amprobe meter and I have it set on dBm V. The incoming line is 120. The line going to the light from black to white measures 60 with switch off and 87 with switch on. Makes no sense. Bad meter?
Old 09-21-2011, 11:26 AM   #8
Rewards Points: 1,536
For the above picture, where are the meter probes touched?
Old 09-21-2011, 11:28 AM   #9
Code05's Avatar
Rewards Points: 1,104
Maybe low battery, that will give a wrong reading. Also make sure it is on AC volts and not dbm, easy to hit a button on mistake.
Code05 is offline   Reply With Quote
Old 09-21-2011, 11:29 AM   #10
In this case (not necessarily all cases) measure voltage with one probe ind the wire nut holding the white wires together and without ever undoing that wire nut.
Old 09-21-2011, 12:09 PM   #11
Licensed Pro
Voltage readings other than 120V on incoming are phantom. Check the connection of the white wires, most likely a problem there.
Also, wires should be wrapped around the screws clockwise, yellow sheathing should be stripped back leaving only a 1/4 in inside the box, and wirenut connections should be made so that you can see the insulated portion of the wire twisted.
Old 09-21-2011, 12:13 PM   #12
I=E/R
a7ecorsair's Avatar
The display in the meter is showing .012 volts or aren't the lead connected?
Old 09-21-2011, 12:53 PM   #13
I hate to admit it, to embarrased tell ya how stupid. But it was my mistake. Thank you for all your help.
Old 09-21-2011, 01:14 PM   #14
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
Come on, fess up.
We have all made stupid mistakes, and we all learn from them.
So, what did you forget to do?
jbfan is online now   Reply With Quote
Old 09-21-2011, 01:19 PM   #15
I knew someone would say that. At the light I twisted the cap to tight and it sheared off the tip of the hot wire. I am glad it was an easy fix.
Wiring a single pole wall switch to a ceiling fan and light. How ? Larry Lambert Electrical 3 03-08-2011 03:52 PM
wiring in line light switch on power cord basicbrand Electrical 4 12-08-2009 09:36 AM
wiring receptacle form light switch olazu Electrical 8 12-03-2009 09:10 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
