New Light/switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 03:21 AM   #1
Question
New light/switch
I'm tyring to install three lights in my basement and run them off a signal switch my question is do I run my wire from the circuit breaker to the light switch and from there to the lights or what should I do? Pleaseme out with this one.
THANKS
Mr.Phillips is offline   Reply With Quote
Old 03-22-2010, 06:20 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 658
I always run the circuit to the switch, then run the wires to the lights.
jbfan is online now   Reply With Quote
Old 03-22-2010, 06:32 AM   #3
Just call me Andrew
Rewards Points: 1,020
Not trying to be rude here...but are you planning to do any work inside your electrical panel? Running wiring to a new switch-->light is a fairly basic project. If you're not sure how to do that, you should research more before going inside the panel.
Andrew
secutanudu is offline   Reply With Quote
Old 03-22-2010, 07:23 AM   #4
Rewards Points: 1,548
The most straightforward method electrically is to run the power to the switch and then to the lights.
Other routings may be more straightforward physically.
It is only a slight step up in complexity to run the power to the light first where the power and switch are connected to the same light connection box. Diagram
You can run the power to one light and connect the switch to a different light if you run 3 wire cable from where the power comes in to the light box where the switch is connected. Diagram
Old 03-22-2010, 11:46 AM   #5
joed's Avatar
Rewards Points: 13,766
If it is a single fixture then I would run from the panel to which ever is closest, fixture or switch. Then on to the other device. If it is the same either way then to the switch first.
Tags
electrical , light switch , wiring
