First you are going to need to figure out what wires are available at the switch to see where you can get power from. You may need to go to the receptacle
Since you only have one black & white set at the switch, it's a switched loop. It needs to be changed to a hot feed, you do that at the switched outlet location. There, all the blacks should connect together, and all the whites connected together, with tails going to refeed the receptacle constantly. Now the black and white at the switch location are hot & neutral. The neutral (white) connects to the whits to the new light, and the black connects to the toggle switch, and the blaqck from the light connects to the other terminal on the toggle switch. Do not re-make the splice at the outlet until the rest of the work and splicing is done, and of course, do all this when the circuit is off.
Pretty simple. You appear to have a switch loop in at the switch location. SO at the outlet location you must have constant power. Figure out which cable is your power in at the outlet location. Rewire the outlet. Then run a new cable to the light location.
Had this diagram saved.
Shows exactly what you want...except there are 2 outlets...but you should get the general idea.
Thank you so much guys! Thats the exact info I needed! The diagram helps a bunch. Now i have to figure out the center of the room for the new fixture. Would prefer recessed lights but maybe harder to figure out with out a pic. Maybe a future question.
Thanks again!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
