New Light Fixture Won't Work After Having Worked Fine Initially - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 10:15 PM   #16
analogmusicman's Avatar
Rewards Points: 560
if it's not obvious,be sure to do all troubleshooting with the breaker OFF! please don't be insulted,lots of people forget this.
analogmusicman is offline   Reply With Quote
Old 08-28-2011, 10:31 PM   #17
dmxtothemax's Avatar
Rewards Points: 5,190
The lamp base is where the light bulb goes in,
Have a look inside it, there should be two metal contacts.
If you can safely put your ac volt meter probs on them,
this will tell you if the power is making it that far or not.
Heres what it can be-
1 - Faulty lamp base.
2 - Wire from lamp base to ceiling faulty.
3 - Loose connections in j box.
Work backwards with voltmeter to find faulty part.
If theres power in lamp base, its faulty and probably not making good
contact with lamps.
If no power, next to check is j box, put volt meter on wires,
If power there ok, then no power at lamp base,
cord is faulty.
If no power in j box, check connections for loose
or wrong placement.
That counterweight would put some strain on the cable,
and the pulley would bend the cable.
So my guess is its the cable thats faulty.
But check everything anyway.
dmxtothemax is offline   Reply With Quote
Old 08-29-2011, 08:07 PM   #18
Thank you dmxtothemax!
docchanka is offline   Reply With Quote
Tags
new light , new light fixture help , new lighting
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 12:23 AM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 06:54 AM
Light fixture doesn't work Monika2024 Electrical 16 12-16-2009 11:35 AM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 05:05 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
