New Light Fixture Wont Turn Off - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 11:06 AM   #1
new light fixture wont turn off
removed old light installed new one, but light stays on. There are four black wires in ceiling, three white wires, another set of white that were clamped together and a red wire. my light fixtures has two lights on it. I connected the blacks to the black and the whites to the white, not sure what to do with ground wire on fixtures either, so when i turned power back on lights came on, but now the wall switch wont turn it off. Do I need to do something with the red wire coming from the ceiling?
cmamwhittaker is offline   Reply With Quote
Old 12-09-2012, 11:11 AM   #2
Rewards Points: 186
If you have a red wire, it's probably a 3 wire setup, and the blacks are just passing through and the red is your switch wire. So you were "probably" supposed to connect red and white to your new light. But with my unexperienced non-electrician knowledge, I would have used my electrical pen to test which ones are hot under which circumstance, i.e. if I flip the switch on/off, does the blacks stay hot? Or is the red the hot switched? Whites (unless marked otherwise) should be neutral normally. I am not an electrician, so take my comment with caution!
Ocelaris is offline   Reply With Quote
Old 12-09-2012, 01:14 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Should have only removed the wires connected to the light fixture and not anything else.
a pic helps.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
Rochsolid (12-09-2012), stickboy1375 (12-09-2012)
Old 12-09-2012, 01:18 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
why does one feel the need to screw with the splice? Just take the old fixture down, and install the new one.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
jbfan (12-09-2012), Rochsolid (12-09-2012)
Bad home wiring? Turn off light-internet drops or motion light turns on drewryjams Electrical 2 07-30-2012 04:55 PM
Three romex into recessed light box - light won't turn off coopns Electrical 12 05-04-2012 08:27 PM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
Adding additional light fixture to switched circuit woodardhsd Electrical 5 07-07-2011 10:06 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
