New Light Deadline! Where Can I Get This - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 03:52 PM   #1
Rewards Points: 956
Question
new light deadline! where can i get this
So we are progressing along upstairs, and the current phase is putting up new ceiling in the bedroom. However, before we do that, i want to install some new LED lights. I already have 2 LED disc lights wired to a switch.
my project is this: i want to install 2 more LED lights in the ceiling, but this time instead of a switch i want to be able to use a remote to turn them on and off. Where/ how can i do this?
basically something like a tv except the remote will be for controlling a set of lights.
thanks!
federer is offline   Reply With Quote
Old 01-15-2013, 04:28 PM   #2
Licensed electrician
Rewards Points: 1,242
Lutron makes a remote switch. Check the Maestro line.
federer (01-15-2013)
Old 01-15-2013, 05:02 PM   #3
Rewards Points: 956
jim! thanks for looking here. havent seen you here in forever. i dont come up to the electrical section much haha
Old 01-15-2013, 07:21 PM   #4
Rewards Points: 956
nevermind i found something else.
new question-how do i install new incandescent sockets? i am thinking i want 2 or 3
edit again-can i chain it with the other LED disc light i already have up?
Old 01-15-2013, 07:56 PM   #5
Rewards Points: 956
here is a pic of what is up now. the light is wired to a switch at the wall. if i connect the new LED remote lights to this light, i can still use the remote for the new lights right? since the IR or whatever is built into the light itself.
Old 01-15-2013, 09:38 PM   #6
Unless there is constant power at the new light the existing switch would need to be on for the remote to work.
Old 01-15-2013, 10:18 PM   #7
Rewards Points: 956
so basically i should wire a new line so its always hot.
because the switch goes on and off. when i turn it off the remote is thus disabled as well.
is thsi right?
Old 01-15-2013, 10:19 PM   #8
Rewards Points: 956
so i guess my question is how do i add in a new line? i would like to keep the switched light to the switch
Old 01-15-2013, 10:28 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
is thsi right?
From your pic there looks to be 2 lines running from the light. If so, you may be able to get power from the light.
How many wire in the box where the switch is?
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Old 01-15-2013, 10:29 PM   #10
is this right?
Correct.
Old 01-15-2013, 10:31 PM   #11
Find a source of power and run that to a new fixture. Leave the existing wiring alone.
Old 01-15-2013, 11:18 PM   #12
Rewards Points: 956
good eye! yea so i have 2 LED lights i plan on putting up. one is in the pic, the other one i have not connected yet. so thats what the loose line is for. it terminates there.
so both of those lights are on the switch.
Old 01-15-2013, 11:20 PM   #13
Rewards Points: 956
whats an easy way to do this? do i just go in the next room and splice in a new line, and drag it over to use?
Old 01-16-2013, 01:27 AM   #14
Rewards Points: 956
just spent the last few hours reading. wow electricians are tough!
so i am only adding 2 new LED lights at like 5 watts each. is there a way to splice new wire from the existing switch, but have it always be hot?
these are the ones i am adding
http://www.amazon.com/HitLights-Colo...I1QVRU63XR1RDM
Old 01-16-2013, 01:46 AM   #15
Rewards Points: 956
ok so here is my new idea:
i have an outlet in the room. i believe its hot. can i just splice into the outlet for my new lights?
in the case that i can do this, when i go to make the connections, am i allowed to put the 2 hot black wires on the same screw?( white goes to the other screw, and ground goes to green)
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 04:00 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
