-   -   new light deadline! where can i get this (http://www.diychatroom.com/f18/new-light-deadline-where-can-i-get-169217/)
federer 01-15-2013 02:52 PM
So we are progressing along upstairs, and the current phase is putting up new ceiling in the bedroom. However, before we do that, i want to install some new LED lights. I already have 2 LED disc lights wired to a switch.
my project is this: i want to install 2 more LED lights in the ceiling, but this time instead of a switch i want to be able to use a remote to turn them on and off. Where/ how can i do this?
basically something like a tv except the remote will be for controlling a set of lights.
thanks!
Jim Port 01-15-2013 03:28 PM
Lutron makes a remote switch. Check the Maestro line.
federer 01-15-2013 04:02 PM
jim! thanks for looking here. havent seen you here in forever. i dont come up to the electrical section much haha
federer 01-15-2013 06:21 PM
nevermind i found something else.
new question-how do i install new incandescent sockets? i am thinking i want 2 or 3
edit again-can i chain it with the other LED disc light i already have up?
federer 01-15-2013 06:56 PM
here is a pic of what is up now. the light is wired to a switch at the wall. if i connect the new LED remote lights to this light, i can still use the remote for the new lights right? since the IR or whatever is built into the light itself.
http://i.imgur.com/LjxyH.jpg
Jim Port 01-15-2013 08:38 PM
Unless there is constant power at the new light the existing switch would need to be on for the remote to work.
federer 01-15-2013 09:18 PM
so basically i should wire a new line so its always hot.
because the switch goes on and off. when i turn it off the remote is thus disabled as well.
is thsi right?
federer 01-15-2013 09:19 PM
so i guess my question is how do i add in a new line? i would like to keep the switched light to the switch
sublime2 01-15-2013 09:28 PM
is thsi right?
From your pic there looks to be 2 lines running from the light. If so, you may be able to get power from the light.
How many wire in the box where the switch is?
Jim Port 01-15-2013 09:29 PM
is this right?
Correct.
Jim Port 01-15-2013 09:31 PM
Find a source of power and run that to a new fixture. Leave the existing wiring alone.
federer 01-15-2013 10:18 PM
good eye! yea so i have 2 LED lights i plan on putting up. one is in the pic, the other one i have not connected yet. so thats what the loose line is for. it terminates there.
so both of those lights are on the switch.
federer 01-15-2013 10:20 PM
whats an easy way to do this? do i just go in the next room and splice in a new line, and drag it over to use?
federer 01-16-2013 12:27 AM
just spent the last few hours reading. wow electricians are tough!
so i am only adding 2 new LED lights at like 5 watts each. is there a way to splice new wire from the existing switch, but have it always be hot?
these are the ones i am adding
http://www.amazon.com/HitLights-Colo...I1QVRU63XR1RDM
federer 01-16-2013 12:46 AM
ok so here is my new idea:
i have an outlet in the room. i believe its hot. can i just splice into the outlet for my new lights?
in the case that i can do this, when i go to make the connections, am i allowed to put the 2 hot black wires on the same screw?( white goes to the other screw, and ground goes to green)
