New LED Under Cabinet Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2014, 08:32 PM   #1
I am installing new LED under cabinet lights in my kitchen. The lights are part of a whole kitchen lighting set. The old lights (fluorescent) and existing wiring have 2 black and 2 white wires plus a ground. The new LED lights only have 1 black, 1 white, and the ground. How do I connect these? Iím guessing combining the blacks with a wire nut and the whites with a wire nut? Or will this burn the house down?
physics90 is offline   Reply With Quote
Old 09-02-2014, 08:41 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
White to white, black to black, bond the fixture with the ground wire.
Old 09-02-2014, 08:43 PM   #3
Thanks for the reply. Just so Iím clear: all three blacks together and all three whites together?
Old 09-02-2014, 08:47 PM   #4
E2 Electrician
If you don't, i'm pretty sure something won't work.
Old 09-02-2014, 08:50 PM   #5
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
The wires feed another spot downstream.
clw1963 is offline   Reply With Quote
Old 09-02-2014, 09:47 PM   #6
After looking more closely I could have seen for myself that the existing light fixture was the same as what I was installing. Guessing itís a parallel circuit to the other lights.
Tags
under cabinet lights Fix'n it Electrical 25 09-07-2013 09:41 AM
Help with replacing under cabinet lights miami mama Electrical 4 10-20-2011 11:03 PM
Want to make under cabinet lights right Dshow Electrical 3 06-23-2011 08:49 PM
Under cabinet Lights? kcrossley2 Electrical 44 06-27-2010 12:14 PM
under cabinet lights Barry J Electrical 3 07-05-2009 11:07 AM
